Yanmar 2YM15 anode replacement
Jul 18, 2025
26
Catalina 275 18 Mt. Sinai
I don't have the maintenace history on the 275 (hull #18) I recently purchased, so I changed the impeller, the oil and two fuel filters, and drained and replaced the oil in the engine and saildrive. I would also like to change the anode, which I have, but can't get the retaining nut off. That's the one that has a sticker warning you not to do it when the boat is in the water. It's takes a 1 1/4" socket, but even after puttin on some penetrating oil and using a breaker bar, it doesn't move. Any suggestions?
May 12, 2020
56
Catalina 275 Sport 31 Quincy Bay
First of all, it's good to see this thread getting some new attention. Regarding your question, I think you might need a breaker bar. I own hull #31 (2016) and haven't replaced that anode yet but you've revised my interest.
Try heat, use a hot air gun and if that fails try an impact driver. It will probably need a ½" driver.
Jul 18, 2025
26
I did try a 1/2" socket, with a breaker bar, but the acces makes using it difficult. Not sure a heat gun will produce enough heat, and I don't want to destroy the label, but I might give it a try.
May 12, 2020
56
I'll try to remove the retainer nut this weekend when I go do my winterizing. I'd be curious to know if anyone has successfully removed it. I'll keep you posted...
Jan 4, 2006
7,870
Seems that you are NOT looking for an anode for a Yanmar 2YM15 (no engine anodes) but more likely the anode(s) for a Yanmar SD25 saildrive. The SD25 is an add-on for the 2YM15.
Do yourself a big favour and get a maintenance manual for the SD25. Seems they are notorious for corrosion problems and are more than likely $$$$$$ to repair.
Good luck with it.
Jul 18, 2025
26
Nice to get the feedback. The anode I am refering to is on my SD20 saildrive. On my boat it is coupled to the 2015 Yanmar 2YM15. It is clearly shown on page 29 of the operation manual (see attached), which also shows a picture of the warning label that is on the 1 1/4" retaining nut.
PMK
Dec 3, 2016
52
Catalina 275S Annapolis, MD
I removed the anode in my saildrive 5 years ago. It looked fine, with no notable metal loss, so I put it back in. Two years ago I inspected it again and it only had very little loss. I replaced it anyway with a new one. In order to get the anode out the first time, I used a racket wrench, with a short pipe extension and gave the end of the extension a hard knock with a hammer. This was enough to release the anode. Removal the 2nd time was much easier.
May 12, 2020
56
I was able to loosen the nut and replace it easily with an 18" breaker bar. Here's the old anode, which I'm guessing is original with the boat (2016). There's obvious discoloration but not much loss of mass - not sure if it needed replacement but I did anyway.
26
Couldn't get mine off today, even with a 1/2" breaker bar. I left a paper towel soaked with penetrating oil wrapped around it. Hopefully that will help make it removable. May have to figure a way to tap it with a hammer, in that confined space, but might wait until spring before I try. My boat is 10 years old, and I don't know if it was ever changed.
