I was hoisting my Dinghy on the fore deck using the pole topping lift as my attachment point, and the pole topping lift is now somehow jammed it seems at the block up the mast. I can neither get it to out or come in. Has anybody experienced this before? I’m not sure what to do. The load was at a slightly outboard angle from the topping lift block, so it’s possible that it jammed in the sheave up there. I have only tugged on it (hard) by hand. I suppose I could try using a winch on the outgoing side.
. Probably not but it only takes 5 seconds so... worth a try.
