Axle fell out
Dr. D
Nov 3, 2018
288
Beneteau Oceanis 35.1 Herrington Harbour North
My anchor locker has two hinges. The axle in one of them (lower one in picture) fell out. Anyone know where I can get a new one? How about info on the size, type, so I can order a new one? Not the worst problem to have, though an odd one.
Sep 30, 2016
395
Island Packet IP 44 Ventura, CA
You will need to improvise a new pin, or get a new hinge. Probably easier to get a new hinge. The pin would need to be stainless steel. Take off the old hinge and see if there is a brand or marking and measure the length and width. Im sure there is a suitable substitute. Hinges are pretty standard. Amazon and ebay have tons of stuff like that. Since its a Bene its probably a metric size.
Jun 21, 2004
3,055
Beneteau 343 Slidell, LA
Call or email Ward Richardson at Beneteau in SC and request a new hinge. Have the model, year, hinge measurements, screw locations, & photo available. He can hopefully provide a match or close substitute & part number, then you can order & pay for it through your closest dealer. The part will be shipped to you. It appears to be a common hinge on Beneteau anchor lockers; mine appears to be same. I doubt that your local hardware store will have quality hinges in 316 SS.
Dr. D
Nov 3, 2018
288
I hadn't thought about the SC Beneteau place. Thanks BigEasy!
Jun 21, 2004
3,055
Doc,
I checked on the Beneteau spare parts site and found four hinges that may be the replacement for yours. Again, I suggest that you contact Ward Richardson ( W.Richardson@beneteau.com) for assistance. Have all of the pertinent info available for him. I forget the protocol for establishing an account; however, select a Beneteau dealer that you want to do business with, tell Ward that you want to establish an account & access to the spare parts site. He will coordinate between dealer & his operation to provide log on credentials. He will give you a part number, you order & pay the dealer. Your part is shipped from Ward in SC & receive it in approximately one week. Somewhat cumbersome, but the Beneteau site was hacked a few years ago & created lots of havoc. The system was changed to present set up for enhanced security; you can no longer order directly from SC. At least, we still have access to the parts catalog, on line, & have a means of ordering parts that are unique to our boat. Good luck!
Jun 21, 2004
3,055
Doc,
I believe I have narrowed my Beneteau search to one hinge. It appears in the 351 anchor locker as well as my 343.
Part 001564, SS Hinge, 60 x 50mm, Cost $14.02 (+ tax & shipping). Best to verify with Ward.
Johnb
Hunter 37-cutter Richmond CA
If all else fails a stainless steel cotter pin is a temporary work around and readily available at any hardware store.
Apr 5, 2009
3,217
They look to me like they could be common SS piano hinge. That is what is used on my Catalina and I have a 24" piece and cut to fit the needed length.
