Hull preparation
It looks like the black probably is antifouling. It’s not uncommon to put a “tracer” layer of paint below the final coat, so you can see when the top coat is wearing down and needs repainting. My guess is you’re finding blue antifouling over a black antifouling tracer coat, over white gelcoat.
40 grit is pretty aggressive so you might be cutting into the gelcoat a bit. I personally wouldn’t say not to use it though - I don’t like sanding any longer than needed either. It might be best to apply an epoxy barrier coat after sanding to build back up any lost gelcoat thickness, ensure you have a good smooth surface, and prevent any osmotic blistering in the future. The discs you showed should be fine, though I’ve had and easier time with mesh disks like Abranet. I find those don’t get clogged with paint dust so much and they keep working more consistently for longer.
colemj
Jul 13, 2004
1,175
40 grit is correct. For this job a rotary sander is going to work better than a RO. Gelcoat on the bottom serves no purpose, and is only there because it is easier to spray the entire mold when building. Don't worry if you sand into it. An epoxy barrier coat could help stop osmosis, but if a 70's era boat hasn't suffered osmosis yet, or you trailer it, it is unlikely to have osmosis now. Sanding into the gelcoat won't increase that possibility. If you do decide to epoxy coat, you will need a clean surface free of any paint at all. This will make the job more involved.
Why do you want all the paint off? Most people just sand enough to get to good adhered previous paint and tooth it, then paint over it.
Mark
Paint companies usually recommend 80 grit. Lately I've been using mesh sand paper, it seems to last longer, clogs less, and cuts faster. There is also less dust in the air when using a vacuum attached to the sander. A rotary disc sander does work faster than a random orbit, however it is a bit harder to control which can lead to gouging.
colemj
Jul 13, 2004
1,175
80 grit is the recommendation for tooth preparation of an old surface. To remove paint altogether will require coarser grit than 80. We are having this done right now (decided long ago that this job was well-worth paying for).
Mesh paper is better, particularly when toothing, but removing this much paint won't matter because one will be changing either type too much to matter. The guys doing our boat use 48" sheets of sticky back sandpaper and just cut out a large batch of discs from it each morning. This paper is sold on big rolls in all the hardware stores here, so suspect it is a common material for floor sanders or something. They go through a lot of discs, so buying bulk paper could save some money.
While perhaps a bit harder to control, a rotary sander is much faster removal than an RO. One of the guys removing paint is using a rotary, and the other a RO. The rotary guy is lapping the RO guy, and both are working equally hard.
Gouging the bottom a bit is inconsequential, as it will just be gelcoat. Any gouge into the gelcoat is easy to feather or fill before painting.
Mark
Oct 17, 2025
16
boomaroo 22 22 Sydney
Hi.
Many thanks for the valuable advice.
I am using 40 grit because there are many layers of paint especially below waterline and I want it to be really smooth, above the WL I can use 80 as it's not that bad.
I see most YouTube using orbital so I assumed that was the go but I must admit it's pretty slow and hard especially lying on your back, will look into these mesh disc today.
Now for paint, since it's a TS it does not need antifoul so I should be able to paint the whole hull , so should I still use an epoxy barrier paint under the WL as a hard finish to fill in all those little dents in the gel coat then paint over it with a polyurethane primer and topcoat?
I also have a keel repair issue,rusted pivot hole, so if you have any knowledge on this then let me know as well. Again thx for the help.
An epoxy primer will fill much of the evidence of sanding. If the bottom isn't perfect that's probably OK unless you intend to race the boat. Check the paint instructions for the top side. 80 grit may be too aggressive. If you have never used polyurethane paint you're in for a treat, it is thinner than water and will take at least 3 coats. Check the manufacturer's recommendation for grit.
Oct 17, 2025
16
Hi.
So should the epoxy primer be put on all the hull or simply under the WL...the above WL is fine but if the epoxy is going to protect the whole hull then why not, I assume I still need primer then top coat on ALL the hull...
Hi.
Your best bet for the correct answer to these questions is to identify the brand of paint you will be using and review the application instructions for that paint. In general you will want to have a good primer and a very smooth surface for polyurethane paint. Because it is so thin and shiny it will show any flaws in the surface preparation.
Alan K
Feb 22, 2004
62
Hunter 380 Norwalk, CT
Years ago, 15?, I stripped my bottom paint and applied Interlux barrier coat. One of the best decisions I ever made! I hired a sandblasting contractor, experienced with boat bottoms, through my yard to remove the old paint. There are abrasives, other than sand, which can be used and are gentler than conventional sand blasting media. The benefit of using a contractor was that he draped the boat and contained all the debris/dust. This was important since my vessel was stored among other vessels.
Once the old paint was removed, priming and preparation were easy. I put on the recommended number of barrier paint coats recommended by the paint manufacturer. Alternating colors (Grey and White) between coats made it easy to see where I had painted. I finished with 2 coats of hard ablative bottom paint (Pettit Vivid). Now I only touch up my bottom paint annually where I to see grey barrier coat beginning to show through. No excess paint buildup. Worth every penny if you plan on keeping your boat for a while.
Alan
H380
Sep 12, 2025
5
Bene F30E AH
I used a carbide scraper to get my 20+ years of bottom pain layers off. No way I could have ever finished the bottom just using a sander.
dLj
Mar 23, 2017
5,255
Alan
H380
I did the same about 3 or so years ago. I had the hull soda blasted and then did the barrier coats. I've sanded far too many hulls in my life time to want to do it again...
A good barrier coat is very high on my list if you are keeping the boat for a long time.
dj
Jun 9, 2008
1,860
- -- -Bayfield
My recommendation is to sand the hull so that it looks like your photo on the left half of the first photo. It looks like there is a cocktail of bottom paints applied through the years. Best to remove it all and start over. Once completely clean, now is a good time to apply a water barrier paint like Interlux' 2000e or similar according to the instructions. Then apply the antifouling paint of your choice. The slot suggests you have a swing keel boat and so an ablative, multi season paint would be my recommendation. That way you won't get a build up because the paint and toxicants shed away from the hull at the same rate and when down to seeing the epoxy (or gel coat, if you don't apply an epoxy water barrier) you know it is time to paint.
Oct 17, 2025
16
Hi all.
So I have basically removed all the paint, antifoul and gelcoat using a rotary sander which has left quite a few gouges etc.
I am going to try to use an orbital now to see if I can smooth these out.
Since it's a trailer sailer I don't need barrier or antifoul so will be spraying pure gelcoat.
Question.
1- if I spray gelcoat it will most likely follow the contours of the gouged out hull so I need to fill these first. So I could use a waxed gelcoat on my first spray then sand the whole hull to get it even and remove the wax OR can I use some form of filler before any gelcoat and still have to sand down. A filler applied with a spatula though will be very tedious as there are so many little gouges.
Then apply a second or 3rd unwaxed gelcoat then topcoat, then final wet sanding.
As for total thickness of gelcoat for bottom of hull is 3mm ok.
Also should I put a pigment into the base coats or wait till the last waxed coat.
Thx.
colemj
Jul 13, 2004
1,175
Spraying gelcoat won't fill gouges. You will need to fair the hull first. This isn't that bad - use a soft easily sanded filler and apply it in the same direction as the hull curve with a 12" spreader. Then get a longboard (this can be a literal long board) and 80 grit and sand it all smooth in the opposite direction that you applied it. Or if you have a really good DA sander and are careful, you can sand it with that.
3mm is way too thick. Typical gelcoat is 20-30 mils, so 0.5-0.75mm.
If you want it colored, then I'd color the entire spray schedule. But what color do you want it? Most boats have white bottoms if not antifouled.
Mark
16
Well just noticed a possible issue..
As you can see from the photos,the yellow is WLine which has been sanded to glass but the blue is top paint. I was thinking of regelling the whole hull but now I don't think I can spray gel onto the blue topcoat..even if I remove it there is still another paint coat,,greeny one...so what to do...just gel it to the blue paint and hope it sticks...
colemj
Jul 13, 2004
1,175
It's difficult to say what's going on there. Are you sure it is gelcoat and not two different paint colors? It looks like blue>green>white, where white was likely the original gelcoat.
Consider painting instead of gelcoat. Particularly if you are experienced with spraying it. Use a 2-part automotive finish from your local bodyshop supplier (I'm assuming you understand the PPE needed for this). It will be a nice finish without the needed wet sand and polish steps with gelcoat. You will need to make sure the hull is smoother and more fair than with gelcoat, so you will be doing sanding anyway.
I also can't figure out what's going on with the bottom. The yellow and green are odd; I think I see old fairing underneath the white; and I assume the dark grey are gouges from the sander. If so on the latter, did it get away from you that far, or where you digging into blisters?
Mark
Painting would be the best bet. There is still a lot of gelcoat and pain on the boat. The only place where the gelcoat has been removed is where the pinkish spots are showing. The rest is gelcoat and paint.
After removing more paint and fairing the hull, apply a couple of coats of an epoxy based primer above and below the water line. Above the water line use a one or two part polyurethane paint. Below the waterline just use bottom paint or VC Performance Epoxy. The VC is marketed primarily to racers, however, in your case its resistance to UV damage gives it an advantage over leaving the epoxy primer bare.
Lately I"ve been using TotalBoat Epoxy Primer with good results. For a one part polyurethane finish TotalBoat's Wet Edge works well and can be rolled on. Alexseal is a 2 part polyurethane finish that also rolls on.
One of the best resources for applying paint and gelcoat is Andy Miller's BoatworksToday YouTube channel.
Oct 17, 2025
16
Mark
So the dark Gray is fibreglass, white is filler and yellow is possibly gelcoat , the last coat before i hit fibreglass....
The top is just old paint so definitely a paint job, poly....
colemj
Jul 13, 2004
1,175
The width, position, and straight edges of the white makes it look like it was a boot stripe at one time. Does this area go all around the boat, or only in the small area in the picture?
Mark
