Engine Rod Knock
Nov 6, 2020
552
Mariner 36 California
What other engine problems could cause a sound in a diesel that sounds the same as engine rod knock?
My diesel has had a very loud metallic knocking sound since i bought her in 2016. I had a mechanic come and listen to it one time and he basically charged me $400 and shrugged his shoulders. I have been watching youtube videos recently and the sound sounds very much like engine rod knock, however we have put over 100 hours easily on the engine with this issue and it runs well so i'm guessing its not a rod bearing or i likely would have seized the engine by now. Is it possible to run an engine for a very long time with a worn rod bearing? What else would make a similar sound , but not quickly destroy an engine?
I have plans to re-power with a new BETA so was not interested in fixing or rebuilding the engine and figured i'd do general maintenance and use it till it died, but it has outlived my expectations. Would be interested to hear some opinions on possible causes. I might try to record it this weekend and post it to youtube.
To add, the noise is constant and changes with rpm's exactly like rod knock does. It does not go away or get worse. The sound is constant and consistent. The only issue with the engine that is obvious besides this noise is, one of the pistons does not combust when the engine is started and white smoke blows out the exhaust for a few minutes until the engine comes up to temperature, then the piston starts to combust normally and the smoke dissapears. Also, one of the exhaust valves is pretty loose and can be moved side-to-side slightly in its guide/holder. Other than that it actually runs pretty good although there is some piston blowby as well.
10,195
Loose Flywheel, bad dampener plate, loose crankshaft pulley.. Worn out camshaft.. worn piston pin bushing. An engine can run for quite a while with a worn piston pin and makes the same double clack per revolution as a bad rod bearing..
I dunno..
Sep 24, 2018
4,451
Catalina 30 MKIII Chicago
I've seen cars run for thousands of miles with a rod knock so it wouldnt surprise me that your diesel can run for 100 hours. I wonder if you can fill the cylinder with oil to lock the piston in place to help further diagnose this issue
Nov 6, 2020
552
I dunno..
Interesting, thanks for elaborating. When i replace it next year/following year, I'm thinking of tearing it apart in my workshop just for the fun of it to learn a little more.
552
Does rod knock get progressively louder/worse as the engine is used? This noise does not seem to have ever gotten any worse.
Jun 17, 2022
520
Hunter 380 Comox BC
Which diesel engine make and model? ??
How many hours? Do you have the previous owner's maintenance records? What is the compression of each cylinder?
Is the noise constant or does it change with RPM? Does it change in frequency or intensity? Is it different immediately after startup compared to once the engine is at operating temperature?
Do you have/use pre-heat ?
Do all 3 cylinders fire up instantly if you restart it when warm?
Does the engine make rated RPM at idle and underway (no wind) ?
Are there any fuel leaks on the engine?
With the engine running, remove the dipstick. Do you feel pressure? Is there enough pressure to blow the dipstick out? A little pressure is normal but pushing the dipstick out is not.
White smoke on startup is common for many marine diesels. Some owners have difficulty distinguishing between grey and white smoke.
For white smoke that persists for more than 30 seconds after startup, I'm suspecting:
• Damaged Injectors
• Faulty Injection Timing
• Damaged Crankshaft Keyway
• Damaged Timing Gear
• Low Cylinder Compression
• Damaged Rings or Cylinder Liners
• Water mixed in the Diesel Fuel (Cracked Head Gaskets, Cylinder Head or Block)
• Damaged Fuel Lines
• Low Fuel Pressure to the Fuel Pump
• Damaged or Incorrect Fuel Pump Timing
Does your engine leak / burn coolant?
The knocking sound that is present in all diesels is due to the rapid combustion once the mixture reaches the combustion point. This is why diesel engines are built much more rugged than gas engines. Some things can cause that combustion to be more sudden.
1. Incorrect timing. Timing the injection pump to the engine is a fairly technical job, best left to your mechanic. I would suspect this if the noise was new/changed and someone had just reinstalled (incorrectly) the injection pump. Most injection pumps will benefit from a service around 4000-5000 hrs.
2. Clogged / worn injectors. Cause a poor spray pattern and a less then ideal combustion. Injectors should be serviced every 1000-1500 hrs. Adding the right fuel additives at each fill-up goes a long way to extending the lifespan of the injectors and reducing wear in the injectors / injection pump. This is especially true in North America where we have pretty poor diesel compared to Europe.
3. Bad fuel. For diesel we want Cetane (the opposite of Octane for a gas engine). Try a cetane booster in the fuel and see if it changes things at all. Have both fuel filters been changed?
4. Valve adjustment. Typically required every 1000 hrs for a small diesel, very often overlooked.
5. Piston/rod slap, bent rod, etc.... This would require a partial rebuild.
6. Bearings ... I'd be shocked if the bearing were worn out, unless the engine was severly mistreated.
7. Engine mounts ... they will only work properly for about 1000-1500 hrs ... have they been replaced? Is the shaft aligned to the engine (shaft coupler gap should be 0.005 in or less).
Can you narrow down where the sound is coming from? Does it change if you are in gear or not?
How to troubleshoot:
a. Go simple/cheap to more complex/expensive
b. Use good lubricity and biocide additives at each fill-up
c. Check engine/shaft alignment and age of engine mounts
d. Measure compression for a warm engine
e. If you have no maintenance records, get the injectors serviced and the valves adjusted
f. If none of the above makes any change, I'd look at the injection timing / fuel pressure
g. After that, you're into a partial rebuild
.... you need to find yourself a reputable mechanic .... The cost of an engine swap is roughly double the cost of the engine itself when you figure haul-out, exhaust/plumbing / engine bed changes and all the other small things you'll pick up and want to address at the same time. It's best done out of the water to realign the shaft strut to the output shaft.
552
This Yanmar had a very unusual ticking noise.
thanks, watched that one. i need to stop watching videos im truly starting to get worried lol...I know the engine is toast, but crap, now im worried about all kinds of problems it probably has. The scariest one was a dropped valve seat that got chewed to shreds on the top of the piston. That one happened to sound a lot like mine. I might just have the injectors rebuilt, pull the head to take a looksie and call it a day.
Likes: marcham
Nov 6, 2020
552
Universal 5432 / Kubota V-1501
Unknown, judging from condition of engine, several thousand would be my best guess. No records. No idea but there is some blow-by.
Sound is present immediately on startup. It increases in speed with rpm's but does not get any louder. frequency and intensity stays pretty consistent. It does not change when engine gets warm.
Glowplugs? yes. It takes two attemps to start with glowplugs. I hold in for 15 seconds, attempt to start. It wont until I hold glow plug button in for another 15 seconds and then starts right up.
4 cylinders. Yes starts back up within 2-3 seconds of cranking when its warmed up.
Not 100% sure there is no rpm gauge, but i know what 2500 rpm's sounds like in cars (drive stick shift for years) and i can get engine to that rpm based on sound easily. It sounds like it goes closer to 3k rpm if i advance throttle full open.
none visible. i always have my head in engine bay. no fluids are leaking.
good question. the dipstick does not move. when i check oil its secure in its holder. i will check this weekend with it removed.
this is plumes of white smoke. well beyond normal. it has that unburnt diesel smell. as soon as the engine comes up to temp and #1 piston begins to detonate fuel, white smoke immediately goes away. If engine is warm and i restart, #1 piston fires normally and there is no smoke.
• Damaged Injectors
I wondered the same about injectors. This was the first thing i was going to address. I have a shop that can re-build them. a project that is coming up soon.
no visible leaks. I need to check and pay closer attention but i dont think its burning coolant. i cant say 100% though.
good to know. i only added a can of Seafoam a couple of seasons ago. I have not added anything else.
good to know. Its been a couple of seasons since filters were changed, but the sound/problem was present before i changed them. new filters did not affect the sound, but they are due for replacement this season with fluid changes as well. i have not used the boat much the past couple of seasons.
I adjusted them a couple of seasons ago. they were a little out but not drastically. it ran slightly better when i adjusted them. one of the valves above the #4? piston (piston opposite side of flywheel) is loose in its guide/seat and can be wiggled from side to side slightly.
which i probably wont do. i'd rather run it until it dies and save that money for a new BETA.
i get the feeling the previous owner (who i never met) did general maintenance on all systems, but he suffered a severe head injury and the boat was left neglected for an unknown amount of time. i suspect a few years possibly. engine looks like it was pretty neglected at some point, although that may not mean it was mistreated. i dont know for sure. it was not in good condition aesthetically.
definitely need replacing, but shaft is tight in cutlass, no movement of engine that i can tell. does not excessively vibrate although there is some vibration.
no change to sound if in gear. it just gets faster or slower depending on rpm. im absolutely convinced its coming from the head or lower in the engine. its too loud to pinpoint. im thinking of buying an engine stethoscope to try and narrow down closer. at first blush i feel like its in the lower half, no the head but i cant say with certainty yet.
good to know. i will be starting with the injectors. i feel like they absolutely need to be looked at.
i can do the swap. its something i would feel comfortable doing. cutlass bearing, aligning, mounts, exhaust, wiring etc...etc is all something i feel like i could do. much of it i have done i just never have torn into an engine before. rebuilding an engine would be well beyond my ability, but all the peripheral stuff i have tackled before. i checked into rebuilding this engine a few years ago and decided it was not worth the time. much of the parts are difficult to get or becoming extremely scarce or non-existent. the engine is 1980 engine. im getting a price on a BETA 35 with transmission this week just out of curiosity, but expect it to be around 8k shipped. BETA 35's without tranny are going for 4k. im hoping to maybe get an engine next season or following.
See replies in red above.
Thanks for taking the time to reply with so much good info. I basically have given up on major repairs on this engine but am willing to tackle any minor ones (like servicing injectors etc...) that may be easy fixes and give me another year or two more out of it. My biggest concern is seizing it up while out sailing, but we are only weekend sailing it for the foreseeable future, no long passages so im always within towboat range. of course i will continue to do general maintenance.
Jun 17, 2022
520
Hunter 380 Comox BC
Based on your response (you know your engine very well ! :) ), I'd do a compression test. After that, I'd inspect the cylinder / piston head (how much is a head gasket?). I'd hold off on servicing the injectors.
Then, do a used oil analysis. Worth the $45 to know if you are about to have a catastrophic failure or if it's something that might be fixable at a reasonable cost...
Then you'd have a bit of info to see if it's worth spending a few days and a bit of money to keep it going a bit longer or if you're better off to start shopping for an engine...
Nov 6, 2020
552
I did an oil analysis a few years ago. Im sure i still have it somewhere on the boat. I dont remember what was in it except i do remember there was above average amount of aluminum i believe, among some other stuff but i cant remember exactly. I will try and find it this weekend. I was considering taking the head off and sending it to a shop for a rebuild.
This video i just came across is a very close approximation (almost exactly) of the sound i hear except maybe in my engine its a tad more metallic sounding (slightly higher pitch) if that makes any sense.
Jun 17, 2022
520
Hunter 380 Comox BC
Aluminum would be from the piston... I think you know where this is going.....
Do you strain your oil or inspect your oil filters after a change?
Nov 6, 2020
552
:D yes nice new shinny BETA 35. I just hope i can make it a couple more seasons. I only run the engine for a few hours a month, so hopefully she makes it. Its been a good learning experience. Once I have a new motor, im going to drag this one to my workshop and tear it down just for fun. Thanks for all the input. Engines are my biggest weakness right now.
I wonder if changing to a slightly lower viscosity oil would help preserve lubricity if its a rod bearing? I'm assuming a worn bearing that doesnt immediately fail is somehow still getting some (enough) lubrication? Assuming thats what it is of course which we still dont know for sure.
3,093
Beneteau 343 Slidell, LA
What is the age & hours on this engine? Why not a rebuild and forgo the cost of a new engine. Seems that it can’t be too serious considering that it has been occurring for 9 years.
Nov 6, 2020
552
No idea on hours. Engine is in rough condition though. My best guess is well into the thousands. im going on long passages to South America when boat is finished, then over to Med. Also will do Alaska, West coast and East Coast north to Canada. Replacing was always in the budget during the refit/restoration. I want a reliable motor i dont have to worry about. This engine is too old. Parts are hard to find or not available anymore. I dont want to be someplace remote and not be able to find a part if something breaks. I will put some work into it. I will likely rebuild the head (have it rebuilt), service injectors at the very least. I dont think i will do much more than that unless something like the alternator goes. I will upkeep it for a year or two more. I'm not quite ready for the new motor yet. I need to finish up on a few other projects first.
552
No i havn't been, but when i do my next oil change this season, I was thinking of cutting open the oil filter to have a look. I will look into straining the oil. My best guess is maybe the engine got neglected for some years, maybe really dirty oil started wearing a bearing or some other part/s. It will be fun to start taking things apart to have a closer look. I'm really interested in pulling the head and looking at top of pistons. It will have to wait until after the holidays though. early spring I think I will start digging into it, although i am going to do fluid changes in next moth or so.
Apr 5, 2009
3,288
I cannot find anywhere you said what make and model your current engine is. If it is a Univeral [Kubota based] engine, full overhaul kits that include everything other than block, head, cam, crank and injection parts for less than $500.
3,093
No idea on hours. Engine is in rough condition though. im going on long passages to South America when boat is finished, then over to Med. Also will do Alaska, West coast and East Coast north to Canada. Replacing was always in the budget during the refit/restoration. I want a reliable motor i dont have to worry about. This engine is too old. Parts are hard to find or not available anymore. I dont want to be someplace remote and not be able to find a part if something breaks.
Considering your extensive cruising plans, I can appreciate your need for a reliable engine and ready availability for replacement parts as needed. Best of luck.
dLj
Mar 23, 2017
5,031
I'm not sure why you would do anything with this engine. You have a new engine slotted anyway - why not just replace it now? Seems like sending good money after bad...
dj
