Winterizing the Jabsco Manual Toilet
Jan 12, 2019
114
Hunter 340 Narragansett
I have search the forums and found From a July 5, 2005 Posting….. “Converting from Salt to Fresh Water”. Which I believe to be my answer.
I simply cannot remove the Jabsco Manual Toilet Intake Hose from the seacock on my Hunter 340 without violently shaking the hell out of thru hull. I have applied Super Lube to the fitting and hose in the spring, heat from a hair dryer, low setting of a heat gun all with no luck, once this hose is on it doesn’t want to release and there is no room to maneuver in the area to pull on the hose. I have to cut the hose about 1 inch with a razor blade and then I can remove it.
Then I can stick the hose in a jug of antifreeze and pump through the toilet, rim and handle. But as you can imagine, I’m running out of hose using this method.
I feel the “Y Valve configuration” you outline is the way to go for me. I have barely enough room under the 340 vanity to place a small jug of antifreeze, pump refill and repeat over and over.
Anyone have any photos of this setup and recommendations for which Y Valve to buy.
This is the one process I battle with every year and it has to stop. I like the aspect of teeing a piece of hose long enough to reach an accessible location. For me probably 2 feet or so.
I just don’t have the space to tee into the sink drain hose as others have suggested but I can get into the dedicated thru hull for the toilet if the Y valve is compact enough.
Thank you for the help, as you can tell I been searching the archives for this one. And this has to stop this year.
From July 5, 2005 Posting….. Converting from Salt to Fresh Water…..
However, if teeing your head intake into the head sink drain isn't practical, there is a much easier way to flush the sea water out of your existing system than removing the intake hose from the thru-hull: using a 3/4" y-valve (which you can probly get from any hardware store) ...tee a piece of hose long enough to stick into a gallon milk jug into your head intake line in a location that is accessible. Close the seacock, stick the hose into the milk jug, turn the y-valve, flush the toilet. Even if the only place you can tee into is in the bilge, moving a y-valve handle sure beats taking a hose on and off a thru-hull.
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
I think you are mixing 2 different ideas…
Teeing into the sink drain is a way to put fresh water into the head intake (by closing the intake thruhull and running fresh water from the sink faucet into the drain (and then pump the toilet valve). Yes, it could be used to pour AF down the drain and then through the toilet.
What I would do is put a small T with a hose thread on one branch of the T. This is a small T and you should be able to find a p,ace for it as close to the thru hull as possible.
Put a cap on the hose thread to cap it. Then, when is is time to winterize, close the thruhull, put a short piece of hose on the hose fitting and stick the other end in a gallon of pink AF. Once you winterize the toilet, replace the cap and open the thru hull…all done.
It would important to find a robust T fitting and cap if this will be cut in below the water line.
Likes: Rich Stidger
Oct 6, 2007
1,176
Hunter H30 1982 Chicago IL
I had the same issue winterizing the head. The hose was impossible to pull off the hose barbs, so it kept getting shorter and it wouldn’t reach outside the locker and into the antifreeze jug without adding a coupler and hose extension.
My solution was to install a 3-way valve just above the through hull valve with a dedicated antifreeze hose long enough to reach outside the locker and into my jug of antifreeze. It makes winterizing the head about a three minute job. I then open the through hull valve after haul out to drain water trapped between it and the 3-way valve. The antifreeze hose just stays in place all year coiled up in that locker and I put a rubber stopper in the end of it so residual antifreeze can’t run out into the locker.
I have similar 3-way valve set ups for winterizing the water system and the engine.
7,770
I've treated my clean water hoses on the head about the same as your experience. They all went together with SuperLube and I've had no problems getting them apart years later. The hose material is 3/4" Trident VAC XHD Sanitation & Potable water hose with a few pieces of Shields VAC XHD Series 148 hose in hidden locations.
Both of these hoses react the same to heat in that they have to be hot enough that you can't hold on to them (maybe 120-130°) before they are flexible enough to slip on and off. You may not be getting them hot enough. Takes time to get up there with a hair dryer but if you've got cast iron self control, you could use a heat gun. Give me a heat gun and the whole lot of hoses would be a pool of PVC on the floor in no time.
DaveJ
Apr 2, 2013
526
I winterize my head with a different method. This assumes you are on the hard.
I find the thru hull under the boat, insert a tube (1/2” ?) into the thru hull, it needs to be a tight fit. Other end of tube goes into your antifreeze jug. Start pumping! When the antifreeze has gone through the whole system, close the thru hull.
I do the same with the engine.
Hope this helps.
Cheers
Dec 2, 1997
9,011
- - LIttle Rock
Winterizing Plumbing
FRESH WATER SYSTEM :
There are two ways to winterize fresh water and sanitation plumbing: with antifreeze and without antifreeze. If you opt for the “no antifreeze” method, ALL the water MUST be removed from the entire system. Why? Because it’s not freezing temperatures that break pipes and crack tanks, it’s because ice occupies about 10% more space than the same amount water…and when it expands, something has to give—and that something will be your water or holding tank, water heater, hose connection, water pipe, or toilet bowl.
ANTFREEZE METHOD (Easiest)
1. Drain the water tanks completely (just turn on all the faucets).
2. Drain water heater. Most have a drain petcock; follow manufacturer’s instructions to find it and use it. Remove both the inlet and outlet hoses, and if necessary use a shop vac to be sure of getting all the water out of it.
3. Do NOT put antifreeze in the water heater. (Ok, you can if you want to, but it’s not necessary). Connect water heater inlet and outlet hoses together to bypass it. Bypass kits for this purpose are available from boat stores and RV supply stores.
Why drain the water heater and bypass it instead putting antifreeze into it? Because it’s not freezing temps that damage pipes, tanks and water heaters, it’s water sitting in a confined space with nowhere to expand. The very small amount of water that may be lleft in the bottom of a water heater has plenty of room to expand, plus water heaters are insulated which protects them from freezing, and it takes forever to flush the taste and smell of antifreeze out your hot water in the spring!
4. After draining the HW tank, tape the circuit breaker in the off position. This will prevent the heater from being accidentally turned on when its empty and burning out the heating element.
5. Put a few gallons of non-toxic antifreeze ("the pink stuff") into the water tank and pump that through the system until all outlets--hot and cold in the galley, head, shower, and any deck wash--run only antifreeze. Leave all the faucets open to make sure there is no pressure in the system.
NO ANTIFREEZE (“dry”) METHOD:
1. Follow the first three steps listed above.
2. Using an air compressor, blow ALL the water out of ALL the plumbing, disconnecting it where necessary to achieve this. The first time you opt for this method can be difficult and labor intensive, but if connections are reassembled in the spring using quick-connect fittings, it becomes a lot easier in the future.
SANITATION SYSTEM
The sanitation system is the easy job:
Pump out the holding tank, then rinse thoroughly to flush out any sludge. This does not require filling the tank and can even be done with sea water. Here’s how:
Put enough water into the tank via the deck pumpout fitting—because that sends the water into the tank at the bottom to stir up any sludge and hold it in suspension so it can be flushed out-- to cover the bottom to a depth of at least four inches. Pump that out. Repeat…repeat…repeat…till you’re pumping out clean water. Then add water one more time and turn on the macerator to rinse it out along with the overboard discharge plumbing.
Alternatively, you can use a washdown pump to do the whole job. Stick the nozzle into the deck pumpout out fitting and turn on the water. When the depth reaches a few inches, leave the water running and turn on the macerator pump. Let both run till the water runs clean (it may be best to do this offshore outside the “3 mile limit”).
By the way, this should be done at least 2-3x a season, more often if live aboard or use your boat year round and in preparation for any extended layup, not just winter layup
Now you’re ready to winterize the system.
Sea water toilet, manual or electric: Just flushing antifreeze through the bowl will not protect the intake line, the toilet pump or the bowl...it'll only go out the discharge to the tank. To protect the whole system, it's necessary to close the toilet intake through-hull, disconnect inlet hose and stick it in a gallon of non-toxic ("the pink stuff") antifreeze. Pump the whole gallon through the system into the holding tank. Do not reconnect head intake hose to the through-hull.
If your toilet’s flush water intake line is teed into the head sink drain line, you can add the antifreeze by just pouring it down the sink--after you've closed the drain seacock, of course! Pump the head or hold the button down long enough to get the excess fluid out of the system as possible.
Fresh water toilet: If your toilet uses onboard pressurized fresh water, you winterized it when you winterized your fresh water system. All that remains is, flush the appropriate amount of non-toxic antifreeze ("the pink stuff") down the toilet into the tank.
Do not use antifreeze in an ElectroScan, Lectra/San, PuraSan, or any other Type I or Type II MSD. Follow manufacturers instructions to winterize all Type I and II MSDs.
After the boat comes out of the water, open all the sea cocks to drain any trapped water. (Omit this step if the boat will remain in the water).
And you’re done!
--Peggie
Jan 12, 2019
114
I Thank you for your help. I saw this Forespar Valve at West Marine (only it was 1.5 inch size) not in my 3/4 inch size. But it seems to be a solution I can easily add to the intake hose.
I can do as Dalliance suggested and leave the Winterizing Hose in place until needed. What do you think? Would this make the Winterizing Hose to long to be effective and to long a draw to pump antifreeze into the toilet?
Thank you again.
Jan 12, 2019
114
My concern with this valve is it doesn’t have 1 threaded end to be able to cap it off when not in use. Search goes on.
Dec 2, 1997
9,011
- - LIttle Rock
I find the thru hull under the boat, insert a tube (1/2” ?) into the thru hull, it needs to be a tight fit. Other end of tube goes into your antifreeze jug. Start pumping! When the antifreeze has gone through the whole system, close the thru hull.I do the same with the engine.Hope this helps.
Cheers
There's a much easier way! Close the intake thru-hull, disconnect the intake line and stick it in a jug of antifreeze. Flush or pump the toilet till the entire jug has gone through the entire system. Reconnect the intake line to the thru-hull but do NOT open the seacock again unless you're on the hard. I suspect this might also work with the engine.
--Peggie
DaveJ
Apr 2, 2013
526
Hi Peggie, I agree with your method, but the poster is having issues getting the hose off of the thru hull, his line is getting shorter every year!!
I was hoping to give him an alternative.
Cheers
Dec 2, 1997
9,011
- - LIttle Rock
Applying a bit of heat using a blow dryer unless you really know what you're doing with a heat gun will solve that problem. A bit of heat and lubrication using KY makes it much easier to replace hoses on fittings.
--Peggie
