Hi! Owned this 2005 Hunter 46LE for a little while. Finally getting to washdown. There's a port. Seems.to be maybe half inch, with a notch in it. Seems.a hose with an oring probably is needed to plug into it. 1st, where to source that thing. Next, there's a white switch on my breaker panel labeled washdown. If I turn it on, nothing happens. Haven't dug into this yet. Should there be a local on off? Should it plumb to my fresh or saltwater? Same or different pump than my freshwater boat pump? I'd take your thoughts on it while I start tracing hoses...as it has it's own breaker, assuming a saltwater pump somewhere that I need to find. Probably a seacock I'm looking for....
