41DS Window Replacement
Aug 26, 2007
282
Hunter 41DS Ventura, California
The forward windows are leaking on my 41 DS. The plexiglass has a rubber gasket attached to the edge which is disintegrating and the window is separating from the aluminum frame. The plexiglass was originally attached using caulk and the gasket created a snug fit to help the seal.
I would like to find a source for a replacement gasket or a complete plexiglass window with the gasket attached. The windows were made by Bomar. Nothing is available on this site. Worst case,
I can strip the gaskets and reseal with Dow 795 but I would prefer to reattach as per the original. any help finding parts would be greatly appreciated!
Jun 17, 2022
371
Hunter 380 Comox BC
Gaskets should not be an issue... there are hundreds of profiles available, find the one that matches the dimensions the closest. I've found a few in the past with google image search.
MFD
Jun 23, 2016
249
Hunter 41DS Pacific NW USA
I have the same task coming up next summer. I have not disassembled yet, but somebody else who posts here did this recently.
For gaskets, barring the availability of a bonafide high quality exact replacement, I was thinking to just go with butyl tape.
Aug 26, 2007
282
MFD
The original gaskets are quite thin and barely allow the window to fit in the frame. I have been unable to find replacement gaskets or complete windows w/ gaskets. I don't think there would be room for butyl tape. Even if it did fit, the window will need to be caulked to hold it in. I have decided to just use Dow 795 to seal and cement the window in place.
I did use butyl tape on one of the smaller windows that was leaking around the frame itself and the hull and it worked quite well once I finally got the frame out of the hull which was pain- took 3 or 4 hours to free it using a guitar string with a helper on one side to saw the old caulk loose (another poster used 40# fishing line to do the same thing). Not a fun project! Good luck and have plenty of beer on hand for the task.
Lots of info here:
Dan_Y
Oct 13, 2008
521
Hunter 36 Hampton
I’m looking at a similar issue on our h36 so I’m watching this thread! The h36 seems to have a similar, but more modestly finished aluminum window frame (fixed port light). The Lexan on the h36 window appears to be completely bedded in Dow 795 on the exterior frame. I can see a 1 or 2 mm separation between the edge of the Lexan and 795 where the water is leaking into the cabin. There is a 1/4” bead of 795 around the perimeter of the lexan on the exterior frame. The bead was nicely finished and could be mistaken for a weathered gasket. The Lexan looks to be sitting on a 3/8” lip provided by the exterior frame that also has 795 on it because I can see a somewhat irregular black bead of 795 going around the perimeter on the interior side of the Lexan.
The exterior frame appears to be sealed (4200?) against the exterior cabin and the interior frame acts as a trim ”ring” that clamps the frames to the cabin wall. I removed a screw from the interior frame and found it’s a machine screw that appears to thread into the exterior frame to clamp the assembly to the cabin. I’m thinking I don’t have to remove the frames, fingers crossed.
Any suggestions are much, much, appreciated.
Dan
282
IF you can see a gap where the water is leaking, can't you just add a bead of 795 to that area to reseal? I highly recommend NOT removing the frame if at all possible!
Aug 26, 2007
282
I would like to find a source for a replacement gasket or a complete plexiglass window with the gasket attached. The windows were made by Bomar. Nothing is available on this site. Worst case,View attachment 234008 I can strip the gaskets and reseal with Dow 795 but I would prefer to reattach as per the original. any help finding parts would be greatly appreciated!
I finally got around to the window reseal. Removed the inner frame and very carefully pushed/ detached the plex. from the outer frame which is held in only by the original calk. It came loose fairly easily since the sealer had deteriorated over the years. Once out, I cleaned it ,removing the damaged parts of the original gasket- the new 795 should seal any gaps which are very small since the gasket is less than 1/16" thick.
The outer frame channel the window mounts in was thoroughly cleaned with a scraper and Acetone. I replaced the window and traced around the inside of the frame with a sharpie to mark where it needed to be masked and masked the areas on the outside of the window/ frame/ hull where exposed. I thoroughly cleaned the edge of the widow with acetone and sandpaper Finally laid a generous bead of the Dow in the channel and pushed the window in place and removed the excess Dow with a finger and damp rags. After a couple of hours I removed the painter's masking tape before the 795 set and it's finished!
A word of warning: I temporarily used Gorilla duct tape to seal it before I was able to perform the repair. Don't do it! The residue left after removing it is an extremely sticky mess: most solvents/ cleaners/ goop-off can craze/ cloud the acrylic. I used olive oil and it came right off. I have used butter to remove tree sap for years so it would probably work as well
Bottom line is it is successfully fixed without removing the frame. Cheers!
MFD
Jun 23, 2016
249
Thank you again for your detailed posts on this work for those of us that will need to do it in the future.
