I'm upgrading the cockpit drains on my Cherubini with bluewater reliability in mind—planning for green water, not just rain. The current setup is typical of the era: molded fiberglass drains, glassed into the cockpit sole and hull, no flanged fittings, no seacocks—just a hose clamped onto a hand-shaped layup that looks like it was built with a bucket of resin and a prayer.
They've held up, but they look rough, and I’m not interested in crossing oceans with systems that rely on luck and legacy glasswork. I like the 1.5" hose size and plan to replace it with high-quality smooth-wall hose. I’m also considering adding seacocks to the cockpit drain outlets, even though they exit slightly above the waterline, just for peace of mind offshore.
I want to bring some real structure and serviceability to this part of the boat—flat flange, proper through-hull, backing plate, valve, and hose run that won’t make me nervous in a seaway.
Open to ideas or lessons learned if anyone’s done this kind of retrofit.
