Anchor Chain source on East Coast
Oct 26, 2010
2,217
Hunter 40.5 Beaufort, SC
Time for new anchor chain. Experience and thoughts from this forum is always appreciated.
My Hunter 40.5 is about 20,000 lbs. Anchoring is only occasional and generally in water less than 12 feet at low tide but in our area the tidal range is about 8 feet so the "effective depth" when at high tide is about 20 ft and there is 5 feet of freeboard. There are pretty good reversing tidal currents in the areas I would normally anchor ranging for 1 to 1.58 knots of tidal current at max ebb. Current chain is 5/16" G4 and works well in my anchor windlass. I don't race so keeping bow weight to a minimum is not a factor.
I'd really like to get US made anchor chain if I can source it.
1. What would be the recommendation for length of chain and for three strand rode for the anchoring conditions I described? I currently have 110 feet of the 5/16 G4 and 100 feet of three strand nylon.
2, I am considering including a Mantus stainless swivel attached with two shackles to the anchor to reduce side load on the shank. I know there are a lot of different thoughts on this.
Any perspectives would be appreciated.
On my recent cruise, when using my Mantus anchor, 110ft of chain, and Mantus swivel, I experienced a new behaviour I do not remember from earlier usage. As the chain was retrieved, the swivel spun enough to remove any twists (as expected). When the anchor lifted from the water, the anchor rotated with the tip up. Previous experiences had the tip rotate down (preferred as it is the way the anchor needs to rest in the bow roller). I am still trying to understand why this is occurring. It requires me to push the anchor with the boat hook to retrieve the anchor correctly into the bow roller.
Oct 26, 2010
2,217
@jssailem I don't have a swivel on right now and most of the time, my anchor retrieves with the tip up and I often to use the "boat hook" rotation trick to get it on the bow roller correctly. It happens more often than not without the swivel. I was hoping the swivel would stop this annoying behavior. "Bad Anchor, Bad Anchor :soapbox:"
  • Ha
I am not sure of the cause. I plan on checking for corrosion on the swivel and will let you know.
Regarding swivels, I think the Mantus is the strongest I have found.
Feb 10, 2004
4,236
Hunter 40.5 Warwick, RI
Pro Anchoring Tip - To get the anchor to orient correctly, simply motor a couple knots in reverse with the anchor just below the water surface. It will orient correctly. Then quickly raise the anchor before it spins around. I have a Mantus swivel and while it helps to un-twist the chain, it doesn't guarantee correct anchor orientation on retrieval.
@smokey73 - I anchor in depths up to 35 feet with 170 feet of G4 5/16" chain. I have all chain, no rope. As I stated above, I have a Mantus swivel. The Mantus design is such that you don't need additional shackles to reduce any side load. The design will not allow a side load to develop.
I do use a scope of 7:1, but beyond 25 feet my scope is obviously reduced. At 35 feet I'm only about 5:1. But some sources claim that for all chain, 5:1 is adequate - maybe not for a storm, but for reasonable winds and currents in a protected anchorage.
Feb 10, 2004
4,236
ACCO brand chain is very common. I would be surprised if there is not a supplier near you. If you search the archives here, I recall that another brand was highly recommended and claimed to be better than ACCO.
Be sure to check businesses that sell chain other than boating stores. I think that hot-dipped galvanized chain is the best, and I'm not sure if ACCO uses that process. A local supplier is almost a must due to the high cost of shipping.
1,618
Hunter e33 Maple Bay, BC
I put one of these on this spring and since then every one of the 25 retrievals have been right side up. Previously it was a 50% chance. Sometimes reversing at 2 kts to turn the anchor right side up in a tight anchor is not feasible or advisable.
Anchor Right - Flip Link
Likes: Rich Stidger
Oct 26, 2010
2,217
Are you using galvanized chain and the Stainless Steel Mantus swivel.
Jun 14, 2010
2,477
It’s not the swivel. The swivel will allow the anchor to “vane“ based on based on (horizontal) water flow. If you drive the boat forward it will point one way, reversing the boat will allow it to point the other way.
Edit: My Rocna Vulcan anchor does the same thing.
Oct 26, 2010
2,217
Hoping to find a LaClede Chain supplier, dealer, or someone who carries this chain so I can get a price on 100 to 150 of 5/16 G43 chain. Will be shopping around but if I can find someone where I can pick it up I can save a bunch on shipping.
Any other recommended chain manufacturers? Is ACCO still USA made?
Jun 14, 2010
2,477
Got mine from
Amy Duzan
Tulsa Chain. Com, LLC
918-392-2829
Fast service and fair price, including shipping for a 300# drum to my boatyard.
Before that I had ordered Acco chain from WM (when it was on sale) and wasn‘t happy with the galvanizing on my order. Rejected it and paid more for the LaClede chain. I later heard Mantus was also reselling Laclede chain Mantus Chain - Mantus Marine
