I have a Yanmar 3HM, and the tachometer reads off the flywheel. The manual says about 700-900 rpm. It starts at 2000 then drops all the way top zero. The engine itself has no change in sound, so it hasn't changed its RPMs. and certainly not to zero. This happens within 4 minutes after starting from cold.
I need help on what to do. I did check the first connection and it seemed secure and clean. No loose wires on the way to the flywheel that I could detect. Since it is the flywheel the alternator wouldn't make a difference right?
Any tips or advice would be great. 3 photos attached:
1) The sensor at flywheel
2) Back of the tachometer
3) Throttle and stop (Governor?) when the engine is not running.
