Hello all,
I’m following up separately from my earlier thread about the flooded engine compartment. Thankfully, we traced that issue to the burp valve overflowing—particularly when operating in reverse. For now, easing the throttle seems to have resolved it, and the engine compartment remains dry.
With the space finally free of water and the engine running more regularly, I’ve discovered what appears to be a transmission oil leak. It seems to be weeping from the shift assembly lever area on my Kanzaki KM2P transmission, which is paired with a Yanmar 2GM20F. I’ll attach a photo for clarity.
I’m wondering:
Is there meant to be a telltale or weep hole at that location?
Is it likely that a gasket or O-ring within the shift assembly has begun to fail?
A fellow sailor suggested it might simply be a matter of tightening things up, since the transmission was rebuilt about three years ago and sat idle until quite recently. Perhaps bringing it back into service has unsettled some of those seals or fittings.
I did mention this in my earlier thread, but that post focused mainly on the water ingress. I thought it best to start a new discussion devoted to this possible oil leak.
Has anyone here encountered a similar leak from the shift lever area on the KM2P? I’d be grateful for any wisdom, experiences, or guidance from the community.
Fair winds and following seas,
TTW91
I’m wondering:
TTW91
