Hunter 30 tanks
May 31, 2007
784
Hunter 37 cutter Blind River
Holding tank, under port Vberth, and water tank, stbd. settee, appear to be molded to the tops of each bench. There is a large fiberglass plate screwed into a recessed lip on each and each one has a leaky inspection port. Based on each lid being covered in white caulking and many tubes of clear silicone then covered in gorilla tape, I suspect that effluent discharge through the tops has been an ongoing problem. How have other H30 owners dealt successfully with this construction?
I am reticent to criticize the design. It could be fine, or perhaps not. It is a new-to-me 44 year old boat. Looking for thoughts and wisdom.
May 27, 2004
2,059
I assume your Hunter 30 is a Cherubinni version.
I own one and to my knowledge, there were no factory installed holding tanks in that model.
Mine came with a recirculating toilet with overboard discharge or deck discharge.
Perhaps other owners did a retro fit and will respond
May 31, 2007
784
81 Cherubini. I am assuming factory as the screwed down lids fit in to a recessed, molded flange.
Apr 22, 2011
977
I think the design of the tanks are sound. They save space in the boat, versus a tank that is designed to fit in an odd space and hold down straps are not needed. The fiberglass lids to the tanks are quiet large and take a while to remove all the screws to inspect and clean the tank, but once removed you have excellent access to the inside of the tank. I did install a Beckson port in the water tank lid so I could quickly add water and not overfill the tank. Never had any leaks on my H27.
Oct 6, 2007
1,180
Hunter H30 1982 Chicago IL
Same design in my ‘82 H30 for both water and waste. Definitely original. Custom fiberglass tanks tabbed into the hull with full size fiberglass lids set in a flanged sitee platform with silicone sealant and screws about every 3 inches. The tanks are an integral part of the sitee platforms which are part of the one piece dropped in interior hull liner.
I’ve been lucky to date. No leaks. If the lids ever do leak, I’ll be removing a lot of screws, digging out old silicone sealant and resealing with the same. I think that’s what you need to do. I don’t know if the silicone around my tanks lids is original or not, but it appears the PO of Dalliance added two more access ports to the baffled water tank for cleaning. If an access port is leaking, it might need a new O-ring, re-bedding or replacement if it’s cracked.
My worst case concern has always been what might happen if one of the tanks underneath fails. Then it’s either a fiberglass repair job or cut out and replace with a bladder type tank I guess. Though removal might compromise structural integrity of the sitees and possibly more, so that’s probably not the direction I would choose. Fortunately they seem quite sound so far at 43 years old.
Overall I think it’s a pretty good design and very space efficient.
PS: Before anyone comments on the clear vinyl hose in the waste tank photo, it’s a permanent winterizing hose attached to a three way valve just above the intake through hull valve. Not depending on it to handle below the waterline water pressure.
Likes: ggrizzard
Oct 9, 2013
41
Hunter 30 Lusby, MD
With respect to the problem you inherited, you will just have to literally dig in and clean up the mess. Any work involving the holding tank is going to be a shitty job. Start with pumping and flushing and pumping and flushing and then remove/replace all the old hoses as they will also be holding stuff and be stinking. You will have to use solvent to clean up the tape glue and then start digging out the hatch sealant. You will have to remove it all and if silicone was use will have to get it dissolved/removed because nothing will stick to it not even more silicon.
The worst case is the tank was full of stuff and water and not winterized and then it froze into a giant block of ice and that is what broke the seal on the lid and more than likely damaged the integrity of the rest of the tank by cracking the gel coat and fiberglass. You could still fix it but you would have to consider how you want to use the boat and if it would be worth the time and effort.
Switching to a composting head might be an option worth considering.
May 31, 2007
784
Thanks for the suggestions, replies, photos. Faith restored. Hoses are pretty new and don't smell. I think cleanup and rebedding is all that is needed. 3M4200 or sikaflex equivalent suitable? I DETEST silicone.
If I were to go composting, which a number of my colleagues have suggested, I would still need to clean the tank. Mask on, dig in.
  • Ha
Likes: ggrizzard
May 31, 2007
784
Flushed the holding tank with water and bleach. Got the lid pried off. Rebedded in butyl tape. My fear with a 3M or Sika caulk was that because there is little access to pry, it could be impossible to remove at a later stage. Some of the screws had stripped out of the coring.
Interestingly, the pump out hose attachment point is several inches above the bottom of the tank. That means that unless you insert the vacuum directly through an inspection port, you will never completely empty the tank. It is a through hull fitting and is placed on the lowest flat surface available. Hope this is useful info.
Oct 9, 2013
41
Hunter 30 Lusby, MD
When I pump out, I open the access port and spray a hose in there to get the stuff on the sides/bottom of the tank stirred up so it will get sucked out. Having some "starter" stuff in the tank helps it to break down the fresh stuff you will be adding. There is "science" involved in keeping your holding tank from turning into a stink bomb. You want to have nature help you and the starter stuff that stays in the tank is part of the natural process like what happens in the composting heads.
Good work, glad you were able to get the lid off without too much trouble.
Dec 28, 2015
1,945
my '78 30' had a poly tank for the black water and has a factory alum. freshwater tank under the port settee. I removed the toilet system for a desicant toilet and will not go back. My freshwater tank was leaking from the outlet neck. I cut a access port in it , cleaned the inside as much as possible and 5200'ed the heck out of it. i didn't consider the system potable from the beginning and defienlty to not now. When that fails, I'm going to cut the top off the whole tank and install a freshwater bladder bag, replace all of the plumbing with pex and switch to potable.
Oct 6, 2007
1,180
Good job. Not a pleasant project. Hope this solves the problem.
I understand your reasoning, but think I would have opted for 3M 4200 or similar instead of butyl tape. Butyl is great for bolted on deck hardware, but it needs to compressed and stay in compression to work. If some of the screw holes are stripped, you might not have the needed compression unless you switched to larger screws or filled the holes with thickened epoxy and re-drilled first. Hopefully it works out. You don’t want to do the job over, but if it turns out you need to, at least the butyl will be easy to remove.
I’ve also noticed that there is no way to get the last inch or two of liquid out of the tank at pump out. I just always rinse the tank thoroughly, filling it with fresh water until it starts to come out the vent through hull, then start fresh with a good dose of tank deodorizing treatment. I triple rinse in the fall and trust that the ½ gallon of antifreeze run through the head & pump will protect the tank and outlet fitting through the winter.
