Finally after one year of procrastination: A year ago I started seriously planning replacing the big plexiglass windows. First I You Tubed how to do it, then I started purchasing the Plexiglass and all the needed supplies. My aim was to change the shape from the old to something more of "The slow moving look"! I sourced my plexiglass and had them round the corners and polish the edges on one side. Everything came last June. It's been sitting in my basement ever since. So today, I got to the Marina by seven am and worked through till 3:30. Got everything done except for the caulking. I thought I'd let it bond a while. I started by removing one side, cleaning the surface of the boat cabin outside wall. I then sanded the area, taped off the area to be primed, applied primer on both the cabin sides and the plexi glass, and finally offered up the glass with the 3M tape using pre hot glued wooden guides for placement. Using a roller I applied pressure. After that I did the other side. Removed the guides and cleaned up. It says after time it becomes pretty much impossible to remove without breaking the glass. I used a special plexiglass primer, 3M High Bonding Tape. Don't want to use screws.
