Shower Sump Pump Woes
Feb 10, 2004
4,245
Hunter 40.5 Warwick, RI
The usual pump for shower sumps is a small 500 gpm centrifugal pump. I have replaced and struggled with these pumps for 25+ years. I have just encountered another pump failure where the shaft simply won't turn. (It was working in the fall at layup) But the normal frustrations are body hair clogs outside the pump body, hair build-up around the impeller shaft, and more soap and hair clogging the corrugated discharge hose. And there is a lot of flow-back when the pump is stopped.
There is a pump made by Whale that claims to be superior to all others, but at a price well over $300. That is not going to happen- I would need two of them!
Here are my solutions: If I wrap the outside of the pump with a plastic gauze-like material, maybe I can trap all of the body hair from getting into the pump itself. Then I can just replace that gauze as required.
I can try a check valve in the output line and just remove it at winter layup so it doesn't cause a freeze issue.
Lastly I can try to replace the corrugated hose with a smooth bore hose that may not trap and build-up with soap and hair. Hose replacement is difficult because much of this hose is hidden behind structures.
Comments? Does anyone have a solution to these issues?
Lower your hygiene standards? :biggrin:
Seriously, we have a similar issue, the pump failed, Atkins no longer makes a pump that fits the sump we have and no one makes a sump that fits the space we have. The old sump had a screen on the inlet to the box that trapped a lot of hair and what not washing out of the shower. You might try a simple inline water strainer. Something like the one below. A smooth bore hose will also help stuff from getting stuck.
Likes: rpwillia
We had a strainer like the one dlochner linked on a previous boat with a centrifugal pump. It worked pretty well for keeping the pump running. Our current boat has Whale Gulper diaphragm pump that needs no filter. It’s nice to not need to clean out a strainer filled with smelly shower residue a couple times a year.
Rick D
Jun 14, 2008
7,206
The last pumps (Rule) I installed have a back flow valve. However, much like the in-line valves I installed before, they ultimately flow back and will clog. I have had better luck adding some Raritan CP to the sump after using it. Good luck!
Feb 10, 2004
4,245
I should have attached a picture of my sump and pump. It is under the shower floor and the pump sucks directly. There is no ability to filter the shower water before the pump. I also tried a duck bill check valve that came with my current Johnson pump. It's a failure, all it does is slow the backwash into the sump.
I will check out the Whale Gulper diaphram pump.
I can't figure out how to post a picture from my Android phone.
colemj
Jul 13, 2004
1,131
We have spent years with the Rule drain boxes like shown above, and while they do trap the gunk, they are obnoxious to clean out, leave gross smelling water in them, and the small pump fails often from accumulated hairs that do find their way out of the strainer and around the shaft. Or they just burn out. The pump isn't difficult to replace, and it is a commonly found one, but it is annoying.
On two boats with these now, we have replaced them with the Whale Gulper pumps that you consider too expensive. We consider it some of the best money spent on the boat. These things just eat and expel anything that goes down the drain. We make no effort to strain and do no maintenance or cleaning of them.
We live full-time on the boat, so the shower is used daily and throughout the year. The current Gulper has at least 3600 showers on it and I haven't even looked at it since we installed it 5yrs ago. Previous boat was the same.
Ours is the "IC" version that has an automatic sensor and does cost north of $300. If you just use yours on a switch you turn on when you shower, just the pump itself is <$150. The only difference is that automatic sensor, and the only reason we have that is because we also have our A/C condesent feeding into it (and the automatic operation when taking a shower is a bonus). Otherwise, the pump is just fine running dry, so no worries about it on a switch.
Mark
Likes: Rick D
Sep 24, 2018
4,678
Catalina 30 MKIII Chicago
Ive read of some Hunters using a macerator instead of a bilge pump to eliminate issues with clogging
colemj
Jul 13, 2004
1,131
Without any straining of debris before a pump using a whirling impeller of any type, the pump is going to fail. I've pulled apart too many macerators with hair wrapped around the blade shaft to the point of cutting through the shaft seal. The OP's solution is either a good straining system prior to the pump, or a diaphragm pump.
Mark
Feb 10, 2004
4,245
Here is a picture of my shower sump(s). I will look at the gulper pump again.
But I still don't understand how a diaphragm pump that by necessity has inlet and outlet valves does not clog.
colemj
Jul 13, 2004
1,131
That picture is helpful. I'm not sure you can fit a diaphragm pump in there, but I also can't tell the depth. I also don't think they are submersible pumps. Pretty sure they are not.
You would need to install a strum box or similar where your current pump is, and a diaphragm pump somewhere in-line in the hose leading from it.
The valves used in the diaphragm pumps are rubber flapper valves, and there is a double layer of them. Similar operation as used on toilet pumps. At most, something might get caught enough to temporarily prevent the flapper from fully sealing, but this just gets carried off soon in the flow.
Mark
Dec 2, 1997
9,011
- - LIttle Rock
A simple inexpensive solution: Raritan only markets their C.P. (part of the product line they bought from me) as a toilet bowl cleaner--and it's a very good one. But it's also the best sump and drain cleaner on the planet, and requires -0- manual labor.
Sumps: when it can stand at least overnight--It's a bio-active (live bacteria) product, so it needs a bit of time to work--fill the sump to about 1/3 full with water to which you've added 2-3 oz of C.P.--run the pump just long enough to pull the solution through it. In the morning, or whenever...C.P. can remain in the sump for months without damage to anything-- flush out the sump and rinse out the pump by running plenty of clean water through it. Sump cleaning done! Repeat as often as necessary.
Sink drains: Again, when it can stand at least overnight: Close the drain seacocks. Put 3 oz CP into the drain, fill drain with clean fresh water. Next morning or when you return to the boat, open the drain seacocks and run plenty of clean water through them. Drain cleaning done! Repeat as necessary.
--Peggie
Likes: Hello Below
The diaphragm pump can be mounted remotely. Ours is mounted in an accessible location under the head sink.
I don't know how they don't clog, but in my experience they don't.
Whale makes a low profile bilge pump that might work. It is a diaphragm pump.
The diaphragm pump works by suction. The same way your Whale manual bilge pump works. As such it can pass all kinds of things through the pump and no moving parts are exposed to the fluid.
Feb 10, 2004
4,245
My final solution:
All of you were correct. The Whale Gulper 220 pump is the way to go. I opted for the non-auto one and I installed it on an existing shelf under the vanity sink. I first removed the shelf and cut a couple areas to allow slight re-routing of the hoses. Post #11 above shows my original sump. It is about 6" deep and the old pump sat in a shallow area that is the lowest point in the sump.
All of that was removed and a new hose was routed from the Whale pump to the sump. I cut a piece of 1/4" sheet PVC and drilled a hole to hold an elbow with a 1/2" short PVC pipe that was fastened to stand about 1/8" off the bottom of the shallow area.
This system works GREAT!! All of the water is sucked up and expelled from the pump. After a shower, there is just a trace of water in the shallow area and no standing water anywhere else.
Thanks to all for your advice.
Here is what my sump looks like now:
