Yea the above views are not uncommon, and I readily admit that for most I am possibly of a different view. Many have just followed so called experts, and sadly many "experts" are not, so we all must make our own assessment. For mer persoanly I try these things and apply logic to the theory. A quick google will reveal the chemistry in some cars is the same as what we are talking about. " Yes, Lithium Iron Phosphate (LiFePO4) batteries are increasingly used in cars, especially in electric vehicles (EVs). " Along the lines stated above its not the LifePo4 thats the problem with high start current. Its the BMS. Mine deals with all of the above and has done for 5 or so years, and I do not always start my engine to assist the windlass. There is no reason for me to do it, as long as the BMW will deal with it, which it will. This is an American boat with heavy loads, 6 electric winches, microwave etc and all the normal starting loads. Lets look at the other commonly stated problem, ie blowing diodes perhaps because the BMS disconnects the battery. I dont know your boats but the chances of my boat not haveing a load would be extremely rare, be it fridges, nav gear audio etc. In my early days of testing for protection purposes mainly due to all the rumor mongering I reduced the cut off load from what I consider was very extreme (800 amps) down to 100amps. This caused a number of disconnects during charging at 80-120amps. I probably did this in the early stages 10-15 times as I slowly cranked the disconnect current up. No days yep if the anchor is coming up and someone uses the microwave it will still disconnect, but that is my choice. People talk about special fusing on the batteries. Bascily if you have any sort of working fuse or breaker system ( so long as it works) there is no great need to make any changes. My boat already had 300amp battery fuses, which I in fact reduced. The bottom line here (in my personal view) you have far more control over your power source with a decent BMS. You can control low shutoff, low charge, high shutoff, high charge, max load for x seconds, etc All things you can't control with other batteries. I actually ran my AGM batteries on there own BMS connected to LifePo4 as test, then later with my start battery, which gives you far more control. The last misnomer as far as Im concerned is the charging side of things. Basically in very simple terms for the live aboard cruiser he need not change a thing in the charging setup (assuming he has at least 3 stage technology) unless they are trying to get the maximum benefit LifePo4. All of your existing charging setup for 99% of cruisers will be less than that of Lithium, the only potential issue is float voltages carried over to Lithium. Having said that I know many will disagree, so send me any setting from your non Lifepo4 batteries that you think would damage lifepo4 batteries if simply carried across.
