Replace or repair O'Day, Daysailer 3 boom
Apr 30, 2025
4
O'Day Daysailer 3 Lake Hopatcong
Yesterday, while sailing in some strong winds, the boom on my Daysailer 3 snapped in half right at the main sheet bail. I'm looking for a replacement or best way to repair. Any suggestions of where to look
Keith
dLj
Mar 23, 2017
4,771
Got ph
Keith
Got photos?
dj
New boom in the future.
Alternatively you could get a sleeve and have the sleeve welded in place.
Booms were not designed to have point stress in their middle. It is less force on applied to the boom if it is controlled at the end.
Jun 1, 2025
3
1995 Freedom 40 Sloop Marinett, WI
Wow. Snapped in half while you were sailing it? Unless your name is Ahab and you laugh at storms, that shouldn't happen.
There must have been some corrosion and/or stress cracking where the bail bolt went through the mast. I would be afraid to trust it myself, since one problem often indicates others. If replacing it doesn't break the bank, I would go that route.
And give the hairy eyeball to all other structural connections and rigging. A boom snapping in heavy wind must have been traumatic. Imagine if it was a chainplate or stay!
Sep 24, 2018
3,998
Catalina 30 MKIII Chicago
Take a pic. You might be able to do an oversized splice or recreate it without a ton of expense. I built a mast for a Force 5 out of aluminum conduit
