Today, on my 2000 Hunter 340, while I was finishing up routing my remote Mic Cable into my pedestal I found a source of a water leak into my aft stateroom headliner. I Didn’t even know I had a water leak in the headliner until I removed a small access panel to see if I could grab the Mic cable (that didn’t work). So were not talking about a lot of water coming in, right now.
But the leak is coming from one of the 2 screws that hold the removable deck access panel covering the steering linkage. They’re 2 inch long screws that I can see in the headliner access area. They hold in tight when screwed down, have some caulking around the hole, but one of them is leaking. I do put some flexible caulking on the threads of the screws when I put them back in, but I think the hole is widening.
So the question I have is…..has anyone else had this leak source? Is there some sort of silicone sleeve I can insert into the holes and then screw the screws into that to seal the holes up?
I have pictures that I hope get the point across.
Thank you for your help.
