Rigger took mainsail out then ghosted. Went to put it back in (1st for this newbie), which appeared to go fine...then wasn't going in right. Bottom of sail was bunching. Kicker boom vang tightened down...not truly perpendicular but close. On review, the hook for the tack is 90 degrees off from the groove the sail is going into...so it doesn't start twisting at the same time...appears to be my issue. Am I missing something? The head goes straight on just fine. If 90 off on tack is OK, do I need to start wrapped in a certain direction first? I see no immediate path to fix this, since the set screw on the threaded part appears bent over ATM and jammed..probably why the rigger bailed. Wonder if he did that or previous owner. Any thoughts people? If you look at the attached pics, you'll see in the mast openings for setting up the sail, that the groove is 90 degrees off the tack hook...
