Hi Folks,
Recently purchased down here in Aus a 1999 Hunter 340 (which having owned for only 3 weeks, have fallen madly in love with already)
I've noticed there's quite a bit of play in the helm (Wheel) before you feel the rudder engage and start to move. This is at rest in the berth. I'm aware of the 'push rod' steering system as I've had the floor cover up investigating AP installation (yep... that's me from the other post.)
With wheel at 'top dead centre' there would be a good 4-5 inches of 'freeplay' either way until you feel the rudder load up. I intend pulling the console apart to investigate as I hate sloppy helms. The box should all come apart fairly easily and be readily accessable. Just wondering if anyone can provide a 'heads up' on what to look for or replace before I begin dismantling. Is there a key way which might be worn or missing in behind the wheel somewhere? I'm sure I'm not the first to suffer 'Wobbly Wheel Syndrome'
Thank you in advance for any tips and experience info cheers. Mark - 'Malua' Hunter 340
