Starting battery
MattA
May 2, 2011
7
Neptune 24 Tucson, AZ
What is everyone using as a starting battery for the 5411/M15 diesel? My boat didn’t come with any batteries and I’m trying to figure out which one to get. Online, Kubota states it needs a group U1 battery. Not sure that will be big enough. Thanks.
Nov 21, 2012
704
Yamaha 33 Port Ludlow, WA
The engine manual should tell you how many cranking amps are required. Purchase a battery that meets the spec.
Nov 21, 2012
704
And a pinch of reserve.:biggrin:
Yeah, maybe. Engineers are pretty conservative to begin with. Adding another safety factor on top of theirs isn't necessarily beneficial. Space, weight, and wallet constraints all need to be considered. I know this guy who went a size larger on his windlass install, and found there was no end to the cascading impacts :biggrin:.
The OP doesn't say if anything else is connected to the start battery. For example, a bilge pump or CO monitor would strongly suggest using a bigger battery than the mimimum required.
  • Ha
The engineers might be conservative, but the boat builders picking wire gauge and connectors based on price aren’t. :facepalm:
A group 24 is a pretty common choice for engines from around that up to at least 30hp.
A group 24 or 27 will be more than enough and it doesn't need to be a "starting" battery. A good "Marine Deep Cycle" battery will also start the engine. I used a Group 24 deep cycle battery for years on my 35hp Yanmar. A 115 hp Nanni requires a minimum of a group 31.
You may find this article helpful along with many other articles on the MarineHowTo.com site.
MattA
May 2, 2011
7
Manual doesn’t list the required cranking amps, that’s why I asked here to hopefully find out what people with the same boat are using. This will be a starting battery only. Nothing else will be hooked up to it. From advice given on other forums, I will be going with a group 24 starting battery. Thanks for your help.
