Can anyone tell me which terminal is tach, positive output and if needed, sense? This is going to be installed on an M-25XP
My best guess is it connects two parts of the case that would be otherwise electrically isolated. The Hitachi is probably a case grounded alternator and the wire is necessary to provide ground to the isolated part.While we are the subject of alternators. What is the purpose of the black jumper wire as seen on Hitachi 60 amp alternator?View attachment 230691
Those look like isolated grounds, so my guess would be that the rectifier has two ground terminals and either can be used. I don't think they need to be electrically connected with a jumper, but it doesn't hurt. The two terminals in different places may make it more convenient in where the negative cable connects.While we are the subject of alternators. What is the purpose of the black jumper wire as seen on Hitachi 60 amp alternator?View attachment 230691
I totally get the function. Sadly, My Westerbeke made M25-XPAC harness has the positive and sense terminals connected at the back of the alternator. One more thing to add to the list...Here's an article that explains the Battery Sense wire and why it is important and how to wire it correctly.
Alternators & Voltage Sensing - Marine How To
Regulator Sensing Voltage at Alternator End The topic of wiring a high performance alternator regulator, and doing it correctly, comes up a lot. One of the most confusing and often misunderstood areas, that can bite into your charge performance, is incorrect voltage sense wiring. This short...marinehowto.com
Sounds reasonable Mark. Rectifier Definitely has two grounds. Noticed on replacement aftermarket Hitachi type alternators, some have the jumper & some don’t.Those look like isolated grounds, so my guess would be that the rectifier has two ground terminals and either can be used. I don't think they need to be electrically connected with a jumper, but it doesn't hurt.
Hitachi uses a jumper design on one of their other alternators that has two rectifier terminals for negative, with a big gauge jumper between. You connect to either one, but the jumper needs to be there because the case isn't used for ground.My best guess is it connects two parts of the case that would be otherwise electrically isolated. The Hitachi is probably a case grounded alternator and the wire is necessary to provide ground to the isolated part.
