I'm looking to refresh my teak. It currently has flaking varnish and is overdue. The issue is that some of the slats on the helm seat (see attached) will not come off the fiberglass. It seems the PO likely used adhesive (possibly 5200, who knows) in addition to the mounting screws (which seem fairly stripped). I had intended to remove and varnish them, along with the princess seats and grab rails, but I do not want to damage the slats by forcing their removal and am looking for an alternate solution.
My question: without removing the slats, what is the best way to refinish them? It seems varnish would make a mess out of the fiberglass between the slats and be impossible to clean off. Is there something else I can use that would effectively refresh the slats while allowing for easy cleanup of the fiberglass between them? I saw that Practical Sailor rated Star Brite Tropical Teak Sealer as the most effective oil/sealer. Would this be a viable option without ruining the appearance of the fiberglass between the slats?
Much thanks for any input.
