VHF SWR results...
Mar 6, 2008
1,417
To the best of my knowledge, the antenna itself needs to be tuned. There is a set screw at the base of the antenna. It should be loosened and the whip portion pulled out or in then test the the transmission. Does your antenna have this adjusting set screw?
Nov 6, 2020
508
Mariner 36 California
Thanks, no, no way to tune as far as i can tell from brochure and data sheet. The antenna base was one big sealed unit. I dont remember seeing anything like that and no mention of it in the sparse documentation.
Nov 6, 2020
508
Yeah, it is a bear to correctly solder the shield of LMR400 without damaging the foam dialectric. I only use crimp/solder connectors for this. Actually I solely use them now for everything because I've never produced a bad one, or had one go bad in use.
Do you have a dummy load? One is very useful for troubleshooting, as you can just walk the system backward until you find the problem.
One thing you can do is disconnect the coax from the radio, go up the mast and disconnect from the antenna and check for a short up there. If you have a break in the coax before going up the mast, then also check there.
If you need to replace the connector up the mast and are having problems soldering the center connector, there are center pin crimp connectors that don't require soldering. I'd choose the crimp/solder connector over that for more robustness, but it will work better than a bad solder job.
Mark
This is good to know. I may need to resort to one of those type of connectors at the masthead. I just hope I can pull enough slack cable to redo the end connector at the mast head. Thats my biggest worry. I dont think that LMR is going to budge. Its in a narrow conduit with another 12gauge wire going to the mast top. May need to lower the antenna and mount it a little lower.
Nov 6, 2020
508
Mark
No, no dummy load. I should probably get one but dont really understand how they work yet.
colemj
Jul 13, 2004
823
They are just a resistor that absorbs the energy and allows the radio to transmit at power like it sees a perfect antenna on the end. So you just plug it in to any connector to test the system up to that part (with the meter in line, of course). If things improve, then the problem is downstream of wherever you plugged in the dummy load, so you just keep moving it down system until you find the problem.
Mark
Likes: BAD ORCA
colemj
Jul 13, 2004
823
This type of tuning mechanism would be very rare on a marine VHF band antenna. I've never seen one outside of automobile types. They generally come tuned to 1/2 or 5/8 or 1/4 wavelength at 156MHz as end fed or dipole or colinear array. Some whips have a removable whip that could be trimmed by cutting, but there is rarely a reason for doing this.
Mark
Nov 6, 2020
508
Mark
Ah thanks. That makes sense.
colemj
Jul 13, 2004
823
Mark,
Here is a text about adjusting marine antenna.
That link sent me to a general google search with a lot of results discussing CB and automobile antennas. The AI chatbot result at the top talked about adjusting a "marine" antenna, but all of the citations it used were for CB antennas.
Searching for "tunable marine VHF antenna" only brought general mobile antennas and a few universal multiband antennas that could be tuned by cutting their whip to the correct size. All marine antennas you will find on boats are pretuned to marine frequencies.
Any fiberglass antenna cannot be tuned. An end-fed steel whip like many use can be tuned by cutting off an appropriate length, but it can't be lengthened. The set screw on antennas that have a removable whip only holds the whip into a socket - the whip cannot be moved in and out to adjust its tune length.
Truly tunable marine VHF antennas may exist, but they are not in common use (I've never seen one).
Mark
Mar 6, 2008
1,417
Since my posting I discovered that there are marine antennas that are not adjustable and other marine antennas that are adjustable.
The link I provided the first line indicates a marine antenna SRW meter and if you continue reading you will find where it talks about how to adjust the length of the whip with the set screw. I would not cut the antenna.
Here is that link
7,604
Alden 50 Sarasota, Florida
I wouldn’t get too hung up on SWR. Lots of things can affect resonance and impedance, length of the radiator being only one.
Changing the electrical length of the antenna small amounts has a correspondingly small amount of SWR change.
The very high SWR the OP cited is neither but almost always caused by other problems such as bad connectors or moisture in the coax.
Likes: marcham
colemj
Jul 13, 2004
823
Here is that link
OK. Now go and find an example one of these adjustable marine VHF antennas. I've searched and cannot outside of one or two portable automotive mounted versions, and these were made to cover the entire 2M band for mobile ham operation. The fact that they can also be tuned to marine frequencies within the 2M band is just emergent from those frequencies being within the 2M band. While that Cobra article describes a theoretical approach, it needs to be noted that none of Cobra's marine VHF antennas are adjustable in this manner. Cobra is also much larger in terrestrial and ham than in marine.
Mark
Nov 6, 2020
508
:D
Thanks for all the help with this. New crimp connectors made it much easier. Everything work fantastic now. I get 7 of the 10 WX channels now, all of them crystal clear and am finally hearing other marine traffic. Luckily I didnt have to go up the mast.
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
From your post 33 I take it that you found that the previously made fittings were defective so everything's OK now. Did you happen to notice what the defective part was? By the way how did you fix it? How did you know it was defective?
Nov 6, 2020
508
They were not defective, I just botched the installation, specifically the soldering.
On my first attempt, I was using these connectors.
They are not a crimp style connector. Instead they are a pure solder type connector. According to my understanding, there are holes in the barrel of the connector that are used to melt solder into which then fuses the sheilding to the body of the connector, however no matter how hard I tried, I could not get the solder to flow into the connector. The best I could get was it to sort of pool up around the solder hole. Also, this style connector threads onto the LMR coax cable and I had a real hard time getting them so thread on and seat correctly. In other words, my connections were not very well done.
In the hands of someone who is capable of installing them correctly, my understanding is that they are superior to the crimp style connectors. Maybe for land based HAM operators this is true, but for the difficulty of doing this on a sailboat, I would only ever use crimp connectors going forward. They are SO much easier to install.
I did learn a lesson though when soldering the copper core wires. Initially I was going by Mainesails technique thats on his website. He lets the copper core wires protrude from the end of the center pin on the barrel. He cuts it down to length after he is done soldering. I had a real hard time getting the core wires hot enough to get the solder to flow correctly doing it this way and botched a couple of them. When I trimmed the core wires so that they were about a millimeter shorter than the center pin on the connector, I had a much easier time soldering the core wire. To add, on my final connection I didnt even bother to solder the core wires and it had zero effect on the SWR reading so i'm not sure its even 100% necessary to do if its too difficult, for example on the top of the mast where soldering might be too hard to do.
In all fairness though, I suck at soldering and have very little idea of the best way to solder correctly. I sort of bumble through it with just enough competence to get decent end results. If I knew better, or if someone is good at soldering, its probably a much easier thing to accomplish.
