Early 80s H36 Strut
Aug 10, 2010
117
Hunter 36, Quarter Berth Model Placid Harbor, Cuckold Crk, Patuxent River
Good afternoon all,
We're in the midst of some winter projects, one of which is replacing the now 42+ year old prop shaft strut. Living in Maryland we are lucky in that Miller's Island Propellor shop in Baltimore still carries the struts. In case anyone has done research and found the information on SBO's website to be confusing, fear not, it is confusing and incorrect.
I went to the shop today in Baltimore and the foreman concluded that model H-34 (to the left of my pink strut) is the proper model number (not H-33 which is to the right) to be used to replace the stock version (at least that is the case for an early 80's H36 sailboat, ours is an '82). The dimensions on the website (including those from Dahler Marine which was the OEM supplier) are incorrect. Here is a snap shot of my old and completely galvanically compromised strut compared to the H-33 and H-34 models. Note the new versions are in an "un-processed" condition, they still need to be cleaned up quite a bit. Hope this helps.
Cheers,
Marc
7,820
It doesn't look too healthy.
Any chance you could scrape the surface of your old strut to a few 0.001" and show us what it looks like under the pink skin ? It would be interesting to see how deep the dezincification goes.
Thanks if you would.
Apr 22, 2011
978
Good information. You might want to do what I did and fit a small mushroom zinc on your new strut.
Aug 10, 2010
117
I can certainly grind down some of the strut when I get it back, but the pink is pretty deep. You can kind of see it on the picture, I sanded a small area on the flat part....but I'll inquire about attaching a small zinc to the strut.
As an alternative I was planning to bond one of the strut mounting bolts inside the boat to the engine using some heavy gauge wire...was going to add the shaft log as well to that "circuit" - its my understanding that should then be able to protect the strut and shaft log using the zincs that are on the prop shaft....but if I can safely attached a zinc to the strut without compromising it's strength that may be easier?
Apr 22, 2011
978
No problems with my strut with a hole drilled in the fattest part of the strut. It's had zincs for about 3 years. But it probably does sap a little strength from it, but not nearly as much as dezincification. On my boat I connected one of the strut bolts with a copper wire to the bronze shaft log, to protect it.
If an appropriate new strut is not on the shelf, the old strut can be used to make a mold and a new strut cast. I used Mystic River Foundry in Mystic Connecticut many years ago. Be forewarned it can be rather expensive to go this route.
Yes, you should get some protection that way, but it may not be perfect. For a zinc to protect a metal they need to be in the same electrolyte and electrically connected. Certainly the strut and prop zinc are in the same electrolyte. The electrical path is the somewhat iffy one. The prop zinc’s electrical path is good up to the transmission output shaft. The problem is that the transmission’s lubricated gears don’t make an ideal electrical path to the rest of the engine where your strut bonding wire would be connected.
Likes: chichiflys
Jun 21, 2007
2,118
I don't log on to the forum very much these days. Except yesterday. And observed this current thread. Just in case you have not discovered in the archives just yet, I went through a similar experience about a decade ago. Here is the link to my recount I posted at the time. Read through it. Possibly may give you some ideas.
Pink Strut Blues - Ideas For Replacement
978
My thinking is that with the shaft log bonded to the strut, the electrolyte continuity would be through the exterior bolt heads that secure the shaft log.
Aug 10, 2010
117
Good evening Rardi! Yes I most certainly referenced your posting from several year ago. In fact I printed it out. It sure seems that you had the H-33 strut (slightly shorter) and mine is the H-34. What is even more confusing is the tech at Miller's Island Prop mentioned that the specs on Dahmer's website are incorrect. So when I first got there I asked for an H-33 model (as the website measurements of the H-33 more closely matched the measurements to the strut on our boat, although not quite exactly), but the H-33 clearly wasn't close to the dimensions on my strut when we compared them side to side. The angles between the two are also different....Hopefully when they are done cleaning up the cast piece, installing the bearing, and drilling the holes it'll mach up pretty close with the old one, as I dont want to do a lot of re-alignment....
Side note - I noticed you have a wire connected to a bolt for the strut - do you have a whole-boat bonding system or is that wire connected to the engine block? I was thinking of connecting the strut to the shaft log to the engine block to help reduce galvanic corrosion of the those two pieces by using the anodes on the prop shaft, but it may be futile...Referencing Davidsailor26's post above.
Jun 21, 2007
2,118
You are observant to notice the wire from my pictures!
When I went to install my new strut, I saw that Hunter had originally affixed a bonding wire to one of the strut attachment bolts. The wire had long since broken away. I debated whether to do it again. From one perspective, the strut is electrically isolated from the shaft and all else since the cutlass bearing is rubber. As such the strut may not be subject to galvanic corrosion. Still on my 44 year old boat are the original bronze thru-hulls. Never bonded. I check them at each haul-out by gouging them with a sharp screw driver. As of my last haul-out three years ago, the metal was still gold-yellow. No pink.
But ultimately I decided to again run a grounding wire to the engine block. I was aware of losing some electrical conductivity because of the gear/lube interface. However I have a shaft grounding brush installed. A wire from that is connected to the engine block. I also use a fish anode hanging over the side at all times when at berth. The fish anode is wired to the shaft brush. So the strut is protected by both the prop shaft zinc and the hanging zinc. At least that is the plan!
Aug 10, 2010
117
Ah, all makes sense! I was looking at shaft grounding brushes as well the other day as a work around. But considering we got 40 years out of this strut gives me some confidence that I'll get to enjoy this for some time still.
Aug 10, 2010
117
Whelp. This continues to be a saga. Received the H34 strut today. It’s not a perfect fit. Seems as if the angle is off. So it looks like I’ll need to fill in the gap with dynaglass as well. Although my new strut angle is different than Rardi’s in the opposite way. I’ll need to fill in the gap towards the front of the strut base. I don’t think I’ll want to adjust the engine that much. Fun times these old boats. Oh, did I mention after blasting off all the old bottom paint I also have a huge blister project to contend with? It’s been a great start to 2025.
2,118
Yes, coming up with solutions with old boat DIY is fun! Sometimes when I am working on a project in my garage with the door open, neighbors walking by will ask what am I doing? My usual reply is "If I knew, what's the fun in that!"
Thanks for your update and your photos.
Just to recall a few of the specifics of my strut replacement that I posted about many years ago:
- Before applying the Dyna glass, first put the packing tape on the mating surface of the strut. By doing so, the Dyna glass will adhere to the hull. But not to the strut. So the strut can be disassembled later.
- During the process, the Dyna glass will squeeze out. Wait until it begins to set up but it is still a little bit flexible. At that point use a utility knife to cut away the excess. Will save a lot of time having to grind away later!
- If the hull/strut bolt holes have not yet been drilled in the strut, after the steps up above are done, align the strut, then from above through the existing holes in the hull, drill down just enough to mark their location on the strut plate. Remove the strut to say a vice. Then you can complete the drilling.
Let us know how it all works out. And any other tips you discovered that might help future owners with the project!
Aug 10, 2010
117
Thanks Rardi. Hope to get some progress this weekend if the temps and rain cooperate. Will do my best to document the saga.
Looking back at my picture of the three struts next to each other, the H34 sits at about 23 degrees, the stock strut I had is at about 19 degrees and the H33 is about 15-16 degrees. Not sure why your model had the H33 and mine had the H34 - those two are about a few inches different in length as well. The Dammer catalog specs are not very close....I had holes drilled in my new strut so will need to address that when I lay up the Dyna Glas.
One more note of interest, I weighed the new/old struts, new one is about 1.3 lbs heavier than the old one, so it lost quite a bit of weight over the years of slowly corroding away!
More to follow soon hopefully.
Aug 10, 2010
117
Finally had time to finish this project...mostly. Because we already had the holes drilled in the strut I needed to use at lease one bolt to line up the strut to the boat....and I needed to use the bolt that would get the strut the closest to the boat in order to squeeze out the most of the gap filling putty - in my case it is the aft bolt hole. This made using the Duraglass a little bit more challenging as a gap filler. Plus I clearly used too much hardener because the mixture kicked off way too quickly before I could line everything up and get inside to tighten the one bolt in order to squeeze out the excess....so round one was a bust. Luckily I was able to remove all the Duraglass material and start over.
My wife suggested we use something that we could inject into the void once the strut was lined up and mostly attached with the single, aft bolt. I had used Thixo and SixTen Epoxy before with much success, so that was our decision....off to West Marine for a tube.
We attached the strut and I tightened the bolt almost all the way....then injected the epoxy into the void, ensuring I had plenty of coverage. Once that was done I simply crawled in the engine bay and tightened the aft bolt/nut of the strut and all the excess squeezed out. Of course this had to sit overnight to cure.....now this is where I made an almost egregious error. While I did use smooth packing tape on the top of the strut base, I should have also used some wax or other release agent....because the next day after it cured the strut was VERY well attached to the boat! Even though it was smooth, epoxy is still able to adhere pretty well to the tape....so I had to break out the torch again and gently heat up the strut; after a few minutes I was able to remove the strut from the boat, leaving behind a nice custom form/mold at the correct angle. Close call for my stupidity. I just need to drill out the forward hole in the boat and then bed the strut in place.
So it would appear Duraglass or Thickened/Injectable epoxy will work. Plenty of working time with the epoxy and you can really smooth it out once it is set in place. Just be sure to use a proper release agent!
Thanks for the tips Rardi!
