Is it possible or even wise to convert a compressed natural gas stove and oven to propane? Of course things like dedicated propane locker, regulator and sniffer would be considered. Would the burners need to be swapped out? Anything else?
Nor I! On a boat I am considering purchasing but this could be a deal breaker.The replacement gas orifices may still be available,, we don't know the make/model of your stove.
The orifices may or may not be available, I really doubt they are. The other major issue with the conversation is tank storage. The locker must have a drain at the bottom of the locker that goes directly overboard to allow any escaped propane to leave the boat. Most CNG lockers were not built with drain because CNG is lighter than air. If the boat you are looking at is not LPG complaint then you are in for some major work or the LPG tanks can be hung on the pushpit.Nor I! On a boat I am considering purchasing but this could be a deal breaker.
Make that, "non-pressurized alcohol stove."an alcohol stove
If it is an Origo, they are no longer in business. I had the 2-burner model on my last boat….they are ok...but I much prefer propane.Make that, "non-pressurized alcohol stove."
I like mine a great deal, by the way.
While it's true they are no longer in business they are not difficult to find on the used market.If it is an Origo, they are no longer in business. I had the 2-burner model on my last boat….they are ok...but I much prefer propane.
My previous boat had a CNG stove/oven and at one point I considered getting one of those adapters. But given the pressures involved it gave me the willies. I'm sure they work just fine--until they don't.I still have my CNG stove on my Legend 37.5. I bought one of the adapters from Ebay to fill my own tanks. It is very easy. Much easier than replacing everything to propane. Also, I put a single 350 W solar panel on my boat, with a 3000 W inverter and use a single burner induction hob for all cooking for the past 2 years. I lit the stove once in 2 years. The oven is a storage cabinet, now.
Thank you very much for providing this information.I can’t answer for Ben, but i suspect he is using what I’ve been using for the past 10 years (link attached). I refill my own CNG bottles (I have 5) at a local station used by garbage truck and other trucking fleets. The stations have dwindled over the years and I’m afraid someday they will be gone. Till then, I have no problem spending a couple of dollars to fill my bottles every other year or so. As far as bottle certification, there are services locally available that do this although I have not done that with my bottles yet. Probably will look into that at the next refill.
Boat CNG Tank Refill Adapter | eBay
CNG Tank Refill Adapter This is great to refill cng tanks for boats. Pressure in your tank this makes it very easy to fill your tank at any.www.ebay.com
Thank you Ben for the information. Norm SearleMy previous boat had a CNG stove/oven and at one point I considered getting one of those adapters. But given the pressures involved it gave me the willies. I'm sure they work just fine--until they don't.
Dave is right, I doubt you'll find the kits that were offered when most of the CNG stoves were set up. That being said, I easily found the parts to convert my Tasco 3 burner and oven that was set up for CNG, new, in the 90's.Is it possible or even wise to convert a compressed natural gas stove and oven to propane? Of course things like dedicated propane locker, regulator and sniffer would be considered. Would the burners need to be swapped out? Anything else?
