Dyneema Double Eye
Aug 24, 2014
160
Aphrodite 101 148 Coeur d Alene ID
Any suggestions on how to replace this with Dyneema? It’s 8 3/4” with an eye on each end.
Mar 6, 2008
1,514
Why do you want to replace it? I would not use dyneema. Use 3 turns of 3/8" line.
Much as I like Dyneema eye splices that's a tricky spot. The standard guidance is to bury about 50x the rope diameter, and you won't have the length for that with only about 6" between the eyes. If you use 1/8" dyneema and a 3" bury off each eye you'd only have about a 24x bury. You could maybe have the tapers overlap and get 4" bury on each, which gets you to 32x bury, but still not very good with slippery dyneema.
Likes: FlimFlamII
Jun 11, 2004
1,933
Oday 31 Redondo Beach
Or couldn’t you just use a dyneema lashing and call it a day? Maybe not elegant but it should work.
The loop spliced dyneema line is certainly a consideration. For the specific application I would have the loop tested to establish the strength of the splice. I have used buried dyneema line on my gates safety gates. They are going on 6 years of exposure. No whipping was used, just the Chinese finger torture grip of a line inside another line. Line shows no deterioration. I'll take a photo next week when I am on the boat. For the application one could use a soft shackle. I have tested these. 1/4" SK62 Amsteel line when tied into a soft shackle has a breaking strength of 10K pounds. This would exceed the force requirement for a sail attachment. I suspect the force for the application on FlimFlam might be about 300-500lbs. In such a case you could use a 1/8" or 3/16" line and have 300% plus safety factor.
From my soft shackle test reports.
DescriptionMin StrengthAvg StrengthTESTED
Break Strength
SS Wgt
7/64" (2.5 mm) Amsteel Blue1,400 lb1,600 lb2,800 lb0.0105 lb
1/8" (3.0 mm) Amsteel Blue2,300 lb2,500 lb4,600 lb0.0175 lb
Likes: Ward H
Mar 26, 2011
4,009
Corsair F-24 MK I Deale, MD
Loop. Double eye (some call them rabbit ears or dog bones) are weaker and harder to make. Then slide it inside 1" tubular webbing. Easy peasy.
You could slide 15mm webbing or a Dyneema chafe sleeve (two short lengths) on to the rope before splicing, to provide wear protection. Or thimbles and siezings. The need for protection depends on what it is mated to; smooth and big, or small and rough.
Apr 22, 2011
976
My boat has a dyneema continuous loop with a metal ring at one end and an eye with thimble on lower end. Works well. The picture also shows a soft shackle used to attach the ring to the sail.
This is a soft shackle made using 1/4” Samson Amsteel. They can be made and length desired. For the task on the boat in the picture I think the 1/8” dyneema would be more than adequate with a 300%safety factor. There is no risk that the buried line will slip when using the soft shackle knot system when compared to the buried loop design.
A 12” loop soft shackle cost approximately $3 usd in materials.
