Protection for Tailing Well Edges
Apr 5, 2021
5
Hunter 430 Boca Raton
Has anyone found a good solution for some sort of Edge Guard to see the Tailing Well edges from getting beat up? I have had my Glass Guy fix them but the keep getting dinged up by winch handless etc. Thanks.
Jan 7, 2011
6,018
Oday 322 East Chicago, IN
Your info says Beneteau 39.5, but you posted this in the Hunter Owners section…
What kind of boat, and do you have a photo? I don’t recognize the term either.
Apr 5, 2021
5
1996 Hunter 430. Picture of tailing well below. No idea where the Beneteau tag came from - never owned one. Trying to get help from customer service to change it.
6,018
You have the profile fixed now!
So the little compartments that hold the lines… do you put the winch handles in there when not in use? That would chip the fiberglass. My friends with H33’s have something similar, but they don’t store winch handles in there…the have separate winch handle pockets.
MFD
Jun 23, 2016
306
Hunter 41DS Pacific NW USA
For items like this, I have used McMaster-Carr online. Their shipping & handling fee can be a little bit for small purchases, but I have found similar sort of clamp-on UV resistant rubber trim that I used for the edges of a portable/flexible solar panel.
I have similar built in line boxes/pockets on my Hunter 41DS. No chips, but not a bad idea to have something around the edges to make sure there never are.
Sep 24, 2018
4,821
Catalina 30 MKIII Chicago
Two ideas although I like MFD's idea a lot: Install a winch pocket inside the well or wrap the metal "arm" of the winch with something to prevent dings
MFD
Jun 23, 2016
306
Heavy Duty Rubber Trim
With the thin aluminum inside, it was was easy to slip on and squeeze down on the solar panel edges and stays on.
