HULL SCRATCHES
Mar 21, 2022
133
Bristol Corsair Tampa
Hi again
As you can see i got a whole starboard side of scratches caused by the hurricane 2 years ago.
I want to make them go away.... But what products would be recommended?
The scratches are superficial only a very few are deeper. Im all ears and eyes
Link/https://photos.app.goo.gl/FEQj73etb61HAKXUA
Jan 4, 2006
7,769
Not clear if you are showing scratches through the blue paint and into the white gel coat below or just scratches in the paint.
If you can take a solution of a teaspoon of liquid dishwashing detergent in a liter of water and wipe down the scratched area, you will see the scratches disappear if they are only paint deep. If they still show white, OUCH !
Take a few stills and let's see them. You may not like what it shows.
Likes: ggrizzard
Mar 21, 2022
133
Thx for tour response, im out and away up to SC tomorrow Sunday abd wont see the biat fir a few weeks. So if the scratches are deeper than they appear what products/technique should i use to blend in the pigment from unaffected areas and cover them.
Thx
Jan 4, 2006
7,769
Hate to rain on your parade but it can't be done. The unaffected areas or "unscratched areas" consist of hard solid paint of some description which are not about to start flowing or conversely give up their pigment to cover surrounding bare surfaces. In order to allow the pigments to move, a carrier is required to float the pigment from the painted surface to the bare surface.
Just one answer I can see and that's a new paint job.
Those scratches look like dock rash that has gone through the paint and probably affected the gelcoat too. The solution is to sand, fair and repaint the whole side. With that much paint damage, there isn't much advantage to just repairing the damage. By the time all the sanding and fairing is done more than 50% of the topside will need repainting. The extra cost will be minimal and you will have a good color match.
Aug 2, 2009
651
Catalina 315 Muskegon
I couldn't get your pictures to come up. But...
You describe scratches over most of the starboard side of varying depth. And you have paint over gelcoat? I'd say DON"T try to sand out scratches that are into the gelcoat, if that means sanding in a localized area, as you'll lose fairness in your topsides. They'll end up looking lumpy. Getting fairness back is a beast. Avoid. I see a lot of sanding in your future, but the sanding needs to be equal and minimal over the entire surface. Of both sides of your boat.
Any deeper scratches should be filled with thickened epoxy, and then sanded flush with the surrounding area.
If it was my boat, I'd resign myself to applying a two-part epoxy paint, and proceeding accordingly with regard to the best procedures for the product you've chosen. Sanding, priming, and so on.
I don't know your familiarity with two-part coatings...they can be sprayed by a pro or they can be "rolled and tipped".
The bad news is that you have a lot of scratches and a fair amount of work ahead of you. Just be glad it's topsides and not decks. The good news is that your topsides are going to come out looking great so long as you put effort into the prep and you're not a klutz when you apply the paint. Stay away from dark colors. Roll and tip can look damn good, but dark colors will bring out the flaws inherent with that method.
Likes: PaulK
Apr 25, 2024
828
I'm in agreement with what others have said. First, it isn't clear from the video what exactly we're seeing. It really appears that there is white gel goat with blue paint over the top, and that the scratches/abrasions are through the blue paint and revealing the underlying white gel coat. Assuming that is the case, there is nothing to do except sand and fill and paint. There is no product that will make this go away.
This is a doable DIY job, but it takes some patience.
Likes: marcham
Apr 10, 2010
153
Catalina 310 166 Dartmouth, Nova Scotia
Total Boat makes a product that you add to your paint that eliminates the need to "tip" after you roll. For an example go to the Boat works Today and search for roll and tip. Andy loves this product and demonstrates how it is used. Should save a lot of work.
The product is Alexseal, not TotalBoat. It is available through Andy's website with a discount for Patreon supporters.
