I'm planning a trip south next year and just spent some time physically measuring my rig. From the mast head to the deck it is 56'9". From the deck plate to the water line it is 6'6" for a total of 63'3", So far so good. The anchor light is 7 inches above the mast head, wind cups are 8', the windex is 24' and the VHF antenna is 32'. In theory I might be able to squeeze by if I remove the windex and VHF antenna. However, I have a friend who went south this year and said that the 65' foot markers on a lot of the bridges were under water and on several so were the 64'. Couple that with shallow spots and I am beginning to think I should just plan to do the trip offshore.
So to my question.... Have any other 49 owners taken the ICW north or south and what was you experience?
Hi Kevin - I have a catamaran with 64’6” air draft (including the wind instruments). I’ve done the trip 4 times between FLL and CT in and out of the ICW, inlet hopping, and partial offshore. We went outside when crew were up to it and weather was favorable, stayed inside when that was more favorable. There were times we waited because neither was a good choice, or we needed to do provisioning/laundry/maintenance. It becomes like a strategy game, balancing time/distance/hazards/weather and bridge opening schedules.
The low fixed bridges (rarely 65 air clearance) that are most problematic are the Pungo Ferry and Wilkerson, and the Flagler Beach Bridge on the Palm Coast has no tide and is dependent on local rainfall. There are quite a few others that are frequently less than 65 at high tide but are tide dependent (E.g. Socaste bridge, McTeer Bridge, Isle of Palms bridge, more….).
You didn’t mention your depth, but you can bypass the Pungo Ferry bridge by using the Dismal Swamp Canal. I don’t recommend the DSC if your draft is deeper than about 5.5 Ft. (Supposedly it’s maintained to 6 ft draft.) Even at 4.5 draft we bumped a few submerged logs but they moved and we had no damage. The Pungo Ferry bridge can have 65 ft air clearance when the water level at this gauge reads zero.
North Landing River near Creeds (This only happens when there is a sustained north wind that lowers the water level in the Albamarle Sound.).
Info on Socaste bridge
Waterway Guide | Navigation Alert Information
There is a wealth of constant information updates on the Facebook ICW group called -
ICW Cruising Guide by Bob423. I highly recommend that you join it and start reading past posts.
Log into Facebook
You can also download Bob423’s safe tracks and import them into your navigation software (Aqua Maps is recommended). Learn more about them and download them free here
Bob423 Long Tracks
