Cracked stringer on project boat
Jul 22, 2024
2
Pearson 37-2 Pass Christian
Any suggestions for securing this stringer? Optimally without taking the mast out if it can be done. I can jack the mast off of the stringers for repair. The prior owner let water leak onto this spot at the base of the mast and it seems to be a stress crack. I’d appreciate any feedback
Jan 7, 2011
5,999
Oday 322 East Chicago, IN
Mast needs to come out.
Hard to tell condition of the stringer on either side of the mast step…but I suspect this will require removing the damaged wood and stringer, fitting in new wood and then glassing it all in place. Remove the old until you are at solid wood.m
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
It irks me that builders uses so much wood in fiberglass boats. They clearly weren't thinking these boats would last for 20, 30, 40, or more years.
If I was restoring a boat I'd be tempted to pull out any structural wood like that and fabricate fiberglass I-beams or box-beams to replace them. (I would look to see if I could purchase them before fabricating.)
Found:
Fiberglass I-Beams - Multiple Sizes Available
I agree with Gary and Greg about how I would approach the problem.
Removing the mast removes the stress on the hull. The stringer is placed to maintain the hull shape and transfer the forces of the mast broadly to the hull. With the damaged wood, the mast forces are transferred to a limited hull area, overstressing the hull and eventually leading to hull failure.
The repair requires easing the stress on the hull to permit the shape to return and shaping the stringers to maintain the hull shape. It appears that once the stringers are back doing their job, you will need to rebuild the mast step.
This is not a job that supports taking shortcuts. You may find cracks in the hull, which contribute to the water in the bilge.
Likes: ggrizzard
Sep 24, 2018
4,683
Catalina 30 MKIII Chicago
There's evidence of a substantial amount of rotted wood. It will be exploratory surgery. keep grinding until you get to solid wood and then start repairing. Take pics of what you find. THis forum has helped me though quite a few fiberglass repairs
Jan 4, 2006
7,769
I would say that "Whatever you replace down there, it must be a plastic such as FRP to avoid what you've got right now." Never use wood in an area which is likely to have water.
Wood has some benefits. It's cheap, it's strong, it's easy to get and easy to work and it is much lighter than sold glass. In the interior of the boat, consideration has to be given to its environment. Many wooden boats last for decades. Letting a wooden boat dry out is not usually good for the planking. I would guess that water damage was from fresh water, not saltwater. But a mast stepped through the cabin top is difficult to seal when every time you tack, it stresses the mast against the cabin and loosens the seal.
Easing the stress on that frame can be accomplished best by removing the mast. If you jack the mast up, that could work too, but get your job done quickly because you don't want an unsupported mast swinging around, assuming you're on the water and that's why you don't want to drop the mast.
By the way, that's a frame, not a stringer. Stringers run longitudinal from bow to stern. They support the frames during construction and lend stiffness to the hull.
Good luck with your repairs.
-Will
Of course Ralph is right in today's world of modern material.
Of note is that we have been making boats out of wood for centuries. While molded fiberglass stringers and pans are used on new boats, the use of wood stringers in repairs of older boats still has merit. The ability to fit and shape a piece of water resistant wood can facilitate the repair of a mature boat. Then care would be given in assuring minimal water exposure and proper drainage of bilges to minimize water inundation helps to lengthen the use of wood in boats.
jviss
Feb 5, 2004
7,090
Yea, and you know what? How long do you think the builders expected them to last? For the Royal Navy in the 19th century it was only five or so years.
jviss
Feb 5, 2004
7,090
I used to fret over wood that's prone to rot. Then I realized, this wood has lasted 45 years. I think my repair will outlast the boat
If it was FRP you would never have to have done that repair. :)
jviss
Feb 5, 2004
7,090
If it was FRP, may have cost more than I'd be willing to pay for the boat. So either way, you're right
PS - This is why boats and water dont mix
I'm not following. Do you mean the boat would have been worth more than you could afford if it didn't have the damage due to the wood?
Sep 24, 2018
4,683
Solid fiberglass would cost more. There's a limit to how much more most of us would be willing to pay for a smaller boat
807
Norseman 447 Olympia, WA
You can build a boat with wood. You can build a boat with fiberglass. It's when 2 materials are mixed that trouble ensues.
Encapsulating wood with glass pretty much assures the wood's destruction once water is introduced.
dLj
Mar 23, 2017
5,173
I'd rewrite that - enclosing wood with glass ....
Encapsulating wood in epoxy designed to penetrate the cellular structure of the wood works extremely well. But the wood needs to be fully encapsulated, otherwise as you say - it will get water infiltration and rot.
dj
jviss
Feb 5, 2004
7,090
dj
The replica of Henry Hudson's boat, Half Moon, was built that way, and they had rot problems soon after building. I recall they used a lot of pine, which rots quickly. I think a wooden boat not encapsulated will probably last longer than one encapsulated!
I friend had a Beetle Cat with a beautifully varnished tiller, probably at lest seven coats, and recoated annually. Once, sailing, the tiller just broke in half! Turns out the only thing left was a thin, outermost layer of wood and the varnish. It had rotted out and was hollow, with no outward signs.
