Hunter 28.5 2GM20 exhaust soot in bilge
Feb 13, 2023
28
Hunter 27-2 Milwaukee
My 1988 Hunter 28.5 with the 2GM20 engine has black sooty water collecting in the bilge. I also have clean exhaust water collecting under the engine. As far as i can tell the exhaust elbow is not cracked. This is a freshwater boat. the exhaust hoses look original I’m thinking: f it replace the muffler and hoses and exhaust elbow in one shot. I’ve seen posts where the exhaust muffler and fuel tank had some kind of incestuous relationship and exhaust water was getting into the fuel tank. Apparently Hunter had some kind of deal To replace the fuel tank with a plastic one?? Mine looks plastic. Also saw a post where the partition between the engine compartment and the starboard lazarette was removed to facilitate access to exhaust elbow. This will be a fall project on the hard. do I need to replace stock muffler? is there a super duper replacement to be had? Near as i can tell the existing muffler looks like a black kettle
Jan 4, 2006
7,581
I'm sorry but your post appears to be one contradiction after another. Could you please answer the following questions so we can help you help yourself :
What evidence do you have this is exhaust water ? Pictures please.
What evidence do you have this is exhaust water as opposed to lake cooling water ?
As far as I can tell the exhaust elbow is not cracked.
What have you done to determine if it's leaking or not. If I checked it during operation, it is either leaking or it's NOT leaking. It's not "as far as I can tell" it's not leaking. Pull the elbow and inspect it AFTER you have wrapped it in paper towel. NO, not on the extremely hot riser as there's no water there. Onhte cooled portion.
And I've heard that some guy in Kalamazoo has built a perpetual motion machine.
This is crap from the internet and you should be able to determine by your own inspection that there is no way exhaust water could to get into your fuel tank. Unless the engine exhaust line is connected to the fuel tank vent line ? ? ? ? Maybe ?
Are you saying you are having trouble accessing your exhaust mixing elbow ? Is this the reason you are unable to determine if the elbow is leaking ? Pictures and an explanation may go far to helping you with this problem.
Is there anything wrong with the existing muffler ? If it's leaking, by all means replace it as it's a source of carbon monoxide. If it's based on this idea that the exhaust system is somehow putting exhaust gasses and water into the fuel tank, maybe not the best idea I've ever heard. Maybe save your money for something more useful like investing in the guy with the perpetual motion machine.
Jan 7, 2011
5,906
Oday 322 East Chicago, IN
I would start the engine and inspect the exhaust path for leaks….maybe the rubber hose is cracked somewhere and this is not as big of a deal as you think. Maybe not even exhaust water at all. Be aware of CO and ventilate the area if possible.
My O’Day 322 (1988) has the same engine. I removed my plastic water-lift muffler once and it had nasty water in it…if the muffler is leaking, that could be the source. But I would think you could find the leak if you inspect with the engine on and water flowing through the system. I have never changed my exhaust elbow (although it is on the list) on my fresh water boat.
I have never heard of the exhaust and fuel tank being ”conjoined”.
On my Hunter 280, there was a panel at the back of the aft berth that could be removed to access the fuel tank and other equipment. Mine was just held in place with screws.
At this point, investigation is your mission…and take photos so we can see what you are dealing with. It certainly helps us understand your situation better.
Likes: FastOlson
Feb 13, 2023
28
Thank you Ralph Johnston for your reply. Harsh, but useful in my continuing search for perfection on this old boat. Note: its original name was ALOPY where the previous owner managed to only erase the J. The soot in
the bilge is carbon black and seems to be washing into the relatively small bilge from under the floorboards..it only appears after running the engine. The Clearwater leak is indeed lake water. Both of these are manageable no big deal. Have not detected any exhaust smell so CO is not a concern at this time. Apparently, earlier (1985 to ?) versions of this boat did have a problem with exhaust water getting into fuel tank- go figure. Hunter had a retrofit plastic tank available to correct the problem.
I’m assuming that this black soot is coming from some sort of exhaust system leak and would make sense that it would come from the muffler where the exhaust/water mix has solids sinking to the bottom then slowly leaking from a cracked muffler. My thinking is replace the whole system as long as I have everything pulled apart with a new muffler and hoses and anything else that be currently at fault or on the verge of being at fault ..So im fishing for responses that may provide that one small clue or bit of info that makes addressing the issue more achievable. Since I’ve already purchased one of those perpetual motion machines I figure one is enough and i would rather spend a couple of bucks on redoing entire exhaust as opposed to doing it on piece at a time based on the age of this Yanmar 2GM20F system. Again thanks for the help
If you’re getting sooty water in the bilge how can you tell that you’re also getting clear water? If you are that suggests you have two separate leaks. Are you sure the clear water is from the engine at all, and not a different source like a thru hull or rainwater?
If the exhaust hose is original from 1988 it doesn’t owe you anything so if it would make you more comfortable go ahead and replace it. Whether that will fix your problem is still unknown. You’re right that one possible source of the sooty water is the muffler. But before replacing that I’d look for more evidence that it’s leaking and try to trace things down better.
The water in the fuel tank situation sounds odd. I could imagine that an exhaust leak would leave water under a metal tank and corrode the bottom, but that would usually put diesel in the bilge and not water in the tank. A leak on top of the tank could maybe corrode the top, but still that putting water in the tank would be pretty unusual. Maybe @Crazy Dave Condon has some recollection of the history, but in any case it sounds immaterial to your current problems since you’ve got the plastic tank.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Lake water leaking into your boat is an indication that your boat is sinking! Find and fix the leak. A small leak can be a big leak very quickly.
CO is an odorless and colorless gas. I have seen people die from CO exposure. Do not take any risk, CO affects you in a way that you don’t even know you are dying and can’t comprehend the need to save yourself. Get a CO alarm and open hatches if you suspect a leak. Sorry if this sounds “harsh”.
Jan 4, 2006
7,581
Yes, somewhat like that nagging old battle-axe you had back in grade school. It's the only way I can get any information out of you. We're not here for a good time. We're here to solve this problem.
My condolences for that slap across your left earhole.
The soot in the bilge is carbon black and seems to be washing into the relatively small bilge from under the floorboards..it only appears after running the engine.
Good. You've established it as carbon black and not just garden variety dirt. When mixed with water, we know it's coming from the wet exhaust system. Finding the leakage point should not be an impossible problem. Firstly, what condition does the exhaust hose look to be in ?
Before leaving the dock, ensure everything around the exhaust system is bone dry and as clean as you can get it. Take the boat out and run it hard for maybe 15 minutes. Slow down and slowly shut down the engine where you can drift for about 10 minutes while someone keeps watch. Go below, and while wearing heat resistant coveralls, run your bare hands over the exhaust system. The entire exhaust system should be cool including the mixing elbow or if hot, you have a problem with injection water flow. Did you find a wet spot in the exhaust system ? Also check the incoming cooling lake water and the antifreeze hoses. The AF hoses will be about 180° F so search gingerly.
If you have an exhaust leak, you will not even know that you're dying from CO poisoning, as @jibes138 so concisely stated. Let's find it right now, the next time you go to the boat.
Discard this from your mind. It never happened and it has nothing to do with this problem. It is nothing more than the incoherent ramblings of an asylum patient out on a day pass.
The Golden Rule of problem solving :
Your boat is now 36 years old and some of this exhaust equipment may have already been replaced previously. You will then wind up replacing equipment which does not need replacing and may still not solve the problem. What does your muffler look like ? Anything like thist ?
Please answer all texts above which are underlined.
In addition, you still have not answered all of my questions from post #2. Some of them such as "clean exhaust water collecting under the engine" will require a detailed answer. We're not getting anywhere until you have answered all questions.
You are the one in control here. Answer all the questions and provide the information we require and we'll get this problem solved, otherwise .....................................
3,811
Pearson/ 530 Strafford, NH
You’re lucky if the problem happens all the time. Like most of the posts, you should be able to find your problem fairly quick. At some point, you may find a problem that only happens once in a while, those are the ones that really cost you money. I Have changed a few parts only to find out that my problem still existed. Besides being a head scratcher, they are really frustrating. Sometimes you need extra eyes to find out where the problem really is. Good luck with your boat.
Jan 4, 2006
7,581
.......................... and every last ^%*(+$@# shred of your sanity.
A tiny little leak in the bow area which eventually finds its way down into the V berth. It only appears in the winter and some years it will skip a winter only to be back the next winter. I have completely encased the exterior bow area in poly for weeks on end and it still continues to drip. There is a long time lapse between being deluged in winter rain until the leak appears in the V berth. Somewhere in the route, there is a capacitance for water.
I HAVE ONLY BEEN SEARCHING FOR THIS LEAK FOR THE LAST TWENTY-SIX ^%&+$*%^*&$&^ YEARS.
Dec 28, 2015
1,944
I'm here for a good time.......and for you to solve my problems.
Jan 4, 2006
7,581
What if you're here for a good time, but not a long time ?
So, what's happened to @inkunzi ? I want to know if he's found the source of that suspected exhaust leak. I hope it didn't get the best of him.
Apr 8, 2010
2,232
I see one little part of the situation that may (perhaps) play a large role in several other parts. The build year: "1988"...... :(
Our boat was built in '88, also.
I started replacing the OEM hoses, in groups, over a decade ago. While the original ones were multi-layer and wire reinforced, they were showing cracks, stiff areas, and in the case of the exhaust hose some seepage.
Over (approx) a decade I replaced all the head-related hoses, all the fuel carrying hoses, all the engine coolant hoses, and almost all the water supply tubing.
Keeping the old stuff in service, way past its (nominal) 20 year replacement schedule involves an owner in a constant battle of staunching one leak after another, repeatedly and depressingly.
I hope you find a way thru the current problem, but do not then erase the thought of carrying out a real program of Preventative Maintenance. :cool:
