Is There Such a Thing as 1:1 "Scope?"
Mar 26, 2011
3,490
Corsair F-24 MK I Deale, MD
The OED is particularly useful for older English words, because part of the project was to gather examples of usage through the centuries. Many publications use it as the tie breaker, after Websters and others, in determining usage of old words, including nautical terms.
An interesting read and good movie on the topic is "The Professor and the Madman."
Likes: Alan Gomes
Apr 5, 2009
2,865
1 to 1 is a 45 d angle. I believe the format is horizontal to vertical. The hypotenuse isn't a factor in the nomenclature. At least that's how ground slopes are defined, which I think the slope of an anchor line mimics, if I'm not mistaken. Roof slopes are the opposite, usually defined by the vertical measurement in inches over 12.
So, a vertical chain would be 0:1.
Scope is the length of line let out relative to the depth, so it is the hypotenuse (ignoring centenary). A 45º angle would be a 1.414 scope. An anchor rode hanging straight down is a 1:1 scope.
Both of your illustrations for talking about the steepness of a hill or roof measure SLOPE which is rise over run [vertical over horizontal]
Likes: Scott T-Bird
Oct 26, 2008
6,130
Catalina 320 Barnegat, NJ
Yep, that's just my particular way of thinking about it - land based.
May 1, 2011
4,420
Pearson 37 Lusby MD
Is that common nautical vernacular
It is common nautical vernacular - did it on all the large gray things I sailed on.
Allowing an anchor or its chain to run out using its own weight is called veering. With the windlass brake set, the ship is backed to set the anchor (cause the flukes to dig into the bottom). The brake is then released and the ship is backed down to veer more chain until it is at the desired scope. Stoppers are then set and the ship is anchored.
5,050
Bavaria 38E Alamitos Bay
Thanks. Maybe it’s enough to just say/write veered (rather than “veered out”).
Apr 5, 2009
2,865
Putting zero into the calculation to mix your drink can work to 'float your boat' as a proportion because it is a proportion but scope is a ratio so zero will sink your boat. Just referring to post #1
A zero scope will not sink your boat. My anchor is always at a zero scope except when I am anchored. It is zero when stored on the bow roller. ;):beer:
dLj
Mar 23, 2017
3,532
Belliure 41 Sailing back to the Chesapeake
This is the specific link:
OED Scope nautical
Hmmm, that link takes me to the Oxford English Dictionary, but not to anything specifically nautical. I'll have to noodle around and see...
I have two hard copies of the OED in my library. I'll have to peruse those to see how they compare. I've never thought to use it looking for nautical terms ..
dj
Jul 27, 2011
5,050
Veer can also mean a shift of wind direction clockwise; versus back, a shift of wind direction counterclockwise.
Likes: jviss
Apr 5, 2009
2,865
I’m not talking to students right now. I asking the experts about a technical interpretation of “scope”, a topic often covered in this forum. We insert a vertical chain into the concept of scope with its (the scope’s) function being one of holding power at the anchor. I suppose zero scope means not anchored. Scope of 1:1 means the chain is vertical with no holding power. More than that it might be laying on the bottom in a heap. So, the instruction begins at a scope of, say, 2:1; 2x the length of rode over bottom depth. KISS me! I shouldn’t explain why scope of 5:1 has greater holding power b/c I might have to use a “math” term, the angle? Maybe I should say “the angle of the dangle” to get them listen for 30-50 seconds.
A zero scope is what you have when the anchor is still on the bow roller. length of rode / depth 0:1
Jul 27, 2011
5,050
From the calculations and posts presented here, it appears that the lowest “functional scope” for anchoring might be about 1.4:1. This is where the rode, fully stretched out, could rise (toward the boat) at 45 d angle relative to seabed. I think this is a useful thing to know.:) Thus, the resultant vector shows that half of the force tugging on the anchor is directed along the seabed, and half is directed toward the surface, etc.
2,865
I think that the minimum scope for any anchor whould depend on the angle between the shank and the flukes. If the shank is pulled at an angle that does not allow the fluke to lay flat of the sea floor, it will have no hope of every setting. On my Mantus M1 that is about 2.5:1.
Likes: Kings Gambit
jviss
Feb 5, 2004
6,860
Tartan 3800 20 Westport, MA
That is an oversimplified model of how a rode or chain falls. It actually falls as a cateenary, and therefore is never straight, except, I suppose, when there's infinite force and infinite holding power. Which is all the better for us, as it means the part attached to the anchor is more horizontal than it would be otherwise.
Jul 27, 2011
5,050
Maybe true, but most models of anything are oversimplified compared to “reality.” That’s why we use them to aid our understanding. Describe a system using as few parameters as is possible. That is, simplify it. Then go from there.;)
Likes: LloydB
jviss
Feb 5, 2004
6,860
Yes, I get that. Ours is even more complicated than just a chain catenary, too, in most cases, as we have chain spliced to rope. I would probably just count the rope as the scope if I had such a rode, but I have all chain.
dLj
Mar 23, 2017
3,532
I've no idea from a theoretical perspective, but from a practical perspective I've always gone with 3:1 as a minimum scope. I would be mighty uncomfortable with anything less. I typically run more like 5:1 but in tight anchorages and not heavy conditions 3:1 seems good enough.
dj
Mar 26, 2011
3,490
dj
I'm sorry. I guess the firewall got it.
The nice thing about the on-line version (free through your public library) is that it contains ALL of the back up. A unabridged version of the OED is not a book, it is a volume that fills a room. Go to your library's page and look for it among the on-line resources. Or ask a librarian.
