I have never used them in 5 years of owning my boat, and none of my other boats had them.
Pulley Car ? Really?They are for the “pulley car” for the jib sheets. This is the best photo I had of those tracks on my boat. I had to crop it a bit to highlight the track for you to see.
The car has a spring loaded pin that allows you to move it along the track for the best fit for your use.
And you've missed the point. EVERY sailboat has a lead block or similar for its headsail. Sometimes they are fixed in place, but the majority are moveable... from pin stop sliders up to multi purchase systems with roller bearing track cars that allow adjustment while the sheet is loaded. And many boats will have more than one pair of tracks, and multiple sets of lead blocks. But what they won't have is a pulley car for adjusting the headsail trim.Don’t get so frustrated.
It is clear, plain language that got the point across.
But I did fail to mention, that they are both in the middle of my boat, between the back and the pointy end. And that I have 2, 1 on the left side and one on the right.
He did use “quotation” marks…Pulley Car ? Really?![]()
LoLIs the "adjustable genoa car" not a pulley car?
-Will
Not sure how this diagram offers any insight to using the term "pulley" in sailboat rigging. Call it what you will, just don't quote it when giving nautical advice to people. I've used the term Jib block, genoa block, lead block, adjustable jib lead block......yada yada.... but if you want to have any kind of credit in a sailing discussion room.... try to limit the term "pulley" to the mechanical, non-rigging stuff, like your auxiliary engine for instance. But... sailing has a distinct lexicon that we, as experienced sailors should practice and promote. I'm not a fan of nit picking the b'jesus out of some things...... you know, like, is it a "gasket" or a "nettle"??? when talking about sail ties...I've seen some term geeks go crazy on what to call the little ropes used to tie off old fashioned reef points. FYI I'm in the "sail tie" camp... which has garnered me a little heat in the past from those humorless preachers
My boat doesn't like to be referred to as "she" or "her". They has become very sensitive to it. When really offended they will go to a "safe dock".I've always thought of my boat as .... a boat.... not a woman. So using countless female pronouns during boat discussions can become annoying.
Then Spanish must really annoy you.So using countless female pronouns during boat discussions can become annoying.
