Color-matching gelcoat
Jun 5, 2024
6
Tartan 3500 Amelia Island, FL
I have a 1992 Tartan 3500. I need to repair some minor hull dings. This boat is not listed on Spectrum Color. I believe I saw somewhere that my hull color is "bamboo." I have been playing around with mixing colors into white gelcoat but am not confident I can get a close enough match on my own. I doubt a premixed gelcoat will matched this aged hull very well. If someone knew a color recipe that could get me started that would be helpful. Any other color matching tips appreciated.
You can check out
for some tips. After 32 years the original color probably won’t be a perfect match anyway.
:plus: regarding Andy at Boatworks Today. After 25 years he has learned a thing or two about fiberglass and boat repair.
Sep 24, 2018
3,994
Catalina 30 MKIII Chicago
I use a RAL color swatch to find the closest match and then have a local gelcoat supplier mix it for me
Jun 5, 2024
6
Thanks for the quick response. Yes, I’ve become a BoatWorks fan and watched all his stuff on this. After messing around a bit I am beginning to think there is a gene for color matching and a gene for singing on key and I did n
Likes: JBP-PA
That is a possibility. There is a genetic mutation that causes color blindness. With it you have problems with color matching.
Even a test.
what do you see?
Jun 5, 2024
6
Ha! I see the 3, but I am generally at a loss to know if I need a little more brown or a little more yellow to get where I want to be.
I understand. Using Andy’s trick of mixing the colors no hardener, i put a little on the area and walk away. Then after a pause, I return and seek my first reaction to the colors. Just learned you need to record the amount of pigment used, in order to be able to repeat the mix.
It really is trial and error. If you aren’t making errors you are very lucky or you’re not trying.
Coincidentally Jamestown Distributors’ weekly newsletter and blog came out today on just this topic. I haven’t watched the video yet to see how it compares to Andy’s older video, but it could be interesting.
6
How timely! More practical detail than the earlier video. I am inspired and encouraged. Pressing on…
