Rivets Used
May 23, 2011
90
Hunter Hunter Vision 32 Daytona Beach
I have to replace two rivets on my Vision 32 Vang Bracket on the mast. Does anyone know if Hunter used stainless steel or aluminum rivets?
Rick D
Jun 14, 2008
7,207
Had mine removed and replaced last year. The rigger used aluminum FWIW.
Likes: teacherspet
May 23, 2011
90
Thanks t
I don't know what material that Hunter used, but when I re-riveted hardware on my mast I used stainless with a liberal coating of Tel-Gel to inhibit corrosion. Just my 2 cents, YMMV.
Thanks Rich a rigger I know said to use stainless with Tel-Gel ordered the later ain't cheap but I have learned the hard way when you go cheap on a boat it will cost you more in the end
May 23, 2011
90
It will be real obvious when you drill them out.
I'd lean towards stainless but maybe have both ready to reinstall.
Good advice Rick. I have a friend who used to be a rigger say the same thing
Tef-Gel or Lanocote are the two products most used to help prevent bimetal stainless/aluminum corrosion.
