WATERLOCK MUFFLER QUESTION
Jan 4, 2006
7,862
OMG no.
My eyes. MY EYES. I CAN'T STOP SEEING IT ! ! !
Maybe if I rinse my eyes with "Holy Water".
Be Gone Devil​
Likes: Ward H
Aug 7, 2021
170
O'day 28 Casco Bay
Interesting thread. I thought I'd a few additional comments in case this type of issue comes up again.
1. The vessel does not know or care where it is, what it is or how fast it is going. The propeller is nothing more than a power absorber. The ONLY thing that matters is that the engine reaches maximum RPM and usually some number of turns above redline, depending on the manufacturer. This is the surest way to confirm that a mechanical engine is not over wheeled. By mechanical I mean that it has a traditional injection and throttle system vs. an electronic engine with mass air flow and throttle position etc. sensors. The latter affords the engineer the opportunity to determine a calculated load at a given RPM. The load, in combination with the RPM will allow closer tailoring of the wheel to the engine.
2. Propping an engine to achieve a given speed is not a wise thing to do unless you know for certain that you have the excess power to do so and you still achieve max + RPM.
3. A good propeller shop can recommend a wheel based on the propeller demand curve published by the OEM. He will usually target slightly under (to the left) of this curve so as to accommodate for increased load due to fouling, extra gear etc.
4. Any waterlift muffler can get filled with rust from the wet elbow. I just changed mine and it had about 1/2" in the bottom.
5. RPM stands for RevolutionS Per Minute. The acronym is therefore singular. "RPMs" would mean revolutions per minuteS which does not make any sense.
Aug 11, 2011
1,020
O'day 30 313 Georgetown MD
1st prize goes to: well a few of you!
To clarify, the boat performed well on a short cruise, summer of 2023. On my return to my marina, due to incredible downpours, I spent time cleaning up, packing, stowing and organizing. As previously stated, I thought I would tidy the hoses and wiring in the engine bay. One of the things I did was to re route the breather hose and placed it under the de compression lever. This was a bad move! I believe by having an ever so slight opening with the lever slightly moved, it had created less power, unburnt fuel exiting the exhaust, hard starting etc. Putting it back has stopped the discoulered exhaust, and it starts up right away. How ever this has only slightly changed the challenge of low RPM's under load. There is a lot of barnacle growth on the prop. Apparently many of my fellow marine slip holders have experienced this also and all are saying that 2023/2024 season on the Sassafras has seen much change in the speed of barnacles and bottom growth, despite freshly bottom painted hulls.
So, smack me stupid, thanks for all your input, it's always something, ain't that the truth!
Aug 11, 2011
1,020
See 14 April post, item 5.
I read it the first time. I hear you. But I ran it more than one minute, so in English English, it's RPM's. Tomato, Tomahto, it's still the same bloody problem! :):):):):)
Definition of rpm from the Cambridge Academic Content Dictionary © Cambridge University Press)
rpm | BUSINESS ENGLISH
rpm
noun
UK (US r.p.m.)
UK
US
plural rpm or or rpms
Add to word list
TRANSPORT
abbreviation for revolutions per minute: used when stating the number of times part of a machine, engine, etc. goes around during a minute:
at 600/7200/19,000, etc. rpm(s) We're trying to make engines that spin at more than 19,000 rpm.
Likes: Hayden Watson
Aug 7, 2021
170
O'day 28 Casco Bay
Sigh. I'm just grateful you didn't quote Wikipedia. I submit that whoever wrote this dictionary entry wasn't an engineer. You are free to do as you wish, but I will tell you that in the 40 years I have been working as an engineer, it is these rookie mistakes that separate the deans from the dilettantes.
Aug 7, 2021
170
O'day 28 Casco Bay
Take your pick gentlemen.
“If you can’t do the little things right, you will never do the big things right.”
- RADM William H. McRaven, USN (Retired Commander, SOCOM)
"The capacity to learn is a gift; the ability to learn is a skill; the willingness to learn is a choice."
- Brian Herbert (Author of several Dune novels)
Apr 5, 2009
3,333
I really doubt that saying RPMs will sink my boat or blow up my engine, so I am good. I also do not make crew walk the plank for saying rope on the boat even though I have a plank permanently mounted [bow sprit].
Jan 7, 2011
6,014
Oday 322 East Chicago, IN
Still ?
Speaking of RPM’s and tachometers, I got a cheap little visual/digital tachometer a while ago to check/verify my Yanmar tach on theme engine panel was reading accurately.
Today, I finally pulled the thing out, stuck a reflective tape on the crank pulley and fired up the engine.
The digital tach confirmed my panel tach is working and pretty accurate!
I upgraded my prop over the winter to a 3-blade, feathering MaxProp. One of the many improvements is that I am no longer “over-propped” and can get 3600 RPM’s without blowing unburned fuel out the exhaust. The MaxProp pitch is adjustable, so I may give it a little more bite next year, but I am happy I can push the engine with out getting fuel out the exhaust. With my old 2-blade, I could not get to 3400 RPM‘s without the black stuff in the exhaust.
NEIKO 20713A Digital Tachometer, Noncontact Laser Photo Sensor with 2.5 to 99,999 RPM Accuracy, RPM Gauge Marker with Batteries Included Amazon.com
Aug 7, 2021
170
O'day 28 Casco Bay
"NEIKO 20713A Digital Tachometer, Noncontact Laser Photo Sensor with 2.5 to 99,999 RPM Accuracy, RPM Gauge Marker with Batteries Included"
Obviously, the the folks at the NEIKO corporation are not dilettantes.
