The time not to visit Desolation is mid-June to mid-Sep otherwise it can be mystical. A return trip by the end of June will put you against the flood of boats heading North. If you can hit a good weather window between mid-May and mid-June, I would highly recommend a trip up to Princess Louisa to see the spring runoff at Chatterbox Falls. It will be something that you will always remember. Waiatt Bay, even during mid-summer months, is a go to anchorage for the reasons @Kings Gambit has discussed. It seems that anytime you stick in a navigational pass that needs a bit of thought to it, most folks avoid it like the plague. If timed correctly transiting the Hole-in--the-Wall is well worth it.Not to impugn Desolation Sound, a magnificent area, but if you have time consider visiting Waiatt Bay near the Octopus Islands. Lots of room, well protected, mostly shallow (30 ft) bottom even away from the shore, good holding, easy beach landing, very scenic, & not crowded. I doubt you’d need to beef up your ground tackle much. The locals in here may disagree but from my few visitations to DS, it’s crowded. There is barely room enough to deploy your wished for full scope in the midst of the other boats and rocky shore. Sometimes a stern anchor or line to shore is needed. Also, a power boat haven it seems—water toys, kids, loud music, etc. All that what the power boaters like to do.
Arriving to the Octopus Islands is more challenging than DS b/c of the narrow passes to enter the area. Swift tidal flow except at or near slack tide. Better, they say, to enter at slack ebb tide; plan accordingly.
Not surprisingly, those are the months when I’ve visited via bareboat charter.The time not to visit Desolation is mid-June to mid-Sep…
Princess Louisa inlet really is a magical place. The one time I went we anchored the night before in well protected Dark Cove in the Jervis inlet. It was a bit less than 30 nm from there to Malibu which gave us some extra wiggle room to have a good time window to pass through the rapids.Regarding Princess Louisa Inlet; yes it’s beautiful. It’s something like 40 n.mi. up those reaches with virtually no place to turn out once underway before the entrance at Malibu Rapids. Another narrow pass with turns and potentially swift tidal flows. Once again, guides recommend passing at the time of slack tide. The fly in the buttermilk is that one really must pass in DAYLIGHT! Forty n.mi. is usually a long, slow trip in a sailboat. If the slack tide is at, or near, twilight or even later and/or you are late arriving, or even if arriving early but having to wait for slack near the twilight; very stressful. That’s a beginner’s mistake. Trust me. You do not want to arrive to that situation of failing light and tidal flow suboptimal to decide to enter the Malibu Rapids, your first time, in a sailboat!Yes, one has to think about what’s ahead.
Hi Len. I've found a number of anchorages around Desolation Sound that receive little to no traffic even during the peak season, as you say. Last season I tried to find a place to drop in Grace Harbor, but was way too crowded so I moved on to a place where I was the only boat. Stayed there a couple of days then moved to another place where there was only one other boat besides ours.The time not to visit Desolation is mid-June to mid-Sep otherwise it can be mystical.
We had a very similar experience in July last year. Passed on Grace, moved on and stayed 4 days rather than the planned 1.Last season I tried to find a place to drop in Grace Harbor, but was way too crowded so I moved on to a place where I was the only boat.
How does your windlass handle the thimble and shackle joint between chain and rope? I understand the joint is more sound than splicing directly to chain, but I also understand a 3 strand splice to chain only costs 10% of tensile strength, and we prefer to keep all our processes as simple and idiot proof as possible. How would I get a thimble and shackle past the gypsy and into the anchor locker?If you have space, I'd use a thimble and splice over a thimble to the chain. The rope to chain splice I use on the bottom of my all chain side so the chain can't leave the boat and I have a rope tail at the end of my chain in case I want it to leave the boat in a hurry, I can just cut the line. But for a working joint like you'll have, I'd splice over a thimble and use a shackle to join them. That's how I did my secondary anchor which is a rode/chain system like you are building for your primary anchor.
I found paint lasts very little time. I went from paint to zip ties. There have been threads about other sytems of marking the chain. You may wish to read through those.
There is also a rule of thumb that most windlasses drop chain at about 3 feet per second. I don't know what happens there when you get to your rode...
dj
Simple answer, you can’t!How would I get a thimble and shackle past the gypsy and into the anchor locker?
That's correct, you can't pass the thimble through the gypsy.Simple answer, you can’t!
Not without manually grabbing the line before the thimble get to the gypsy. Pulling the anchor rode in manually to the chain then inserting the chain in the gypsy.
This places the crew member manning the anchor system in a dangerous situation.
You are much safer to use the largest 3 strand nylon rode you can that will work in your windlass and use a chain to rope splice.
Been there, done that. Much prefer a splice with a thimble. Long splice seems to cause the chain at the splice to corrode much faster than otherwise, even when doing a fresh water rinse after each cruise.For splicing 3 strand to 5/16” G4, Practical Sailor recommends the “chain long splice” and provides a description of the process.
Seems simple enough, however, be sure you can get all three strands of your rope through the last link before you go too far. Ours would only accept two with a struggle, which is why I went with a long splice, but then went back to a thimble splice because the long splice was very difficult as well.I think I’m going with the simple 3 strand splice mentioned by JSSailem above.
Do you have a spare anchoring system? Never used ours yet, but then again you never know when it might come in handy. Stuff happens. On our cruise last season, almost had to cut my main anchor loose because it was hung up on the bottom in Sturt Bay. That would have meant the loss of the anchor and chain. I do have a back up just in case.That said, does anybody have suggestions as to what I should do with the old 100’ of chain, aside from secondary rode?
