In my case, the D stands for Design because I have a neighbor who is very handy with metalwork and has a garage full of tools he enjoys putting to use.
First, I measured the outer diameter of the original car that came on my boat: 7/8".
I had a scrap piece of 7/8" stainless tube on hand, so I had two 3.25" pieces cut and hammered semi-flat to match the contour of the original car. Using about $25 worth of parts from AliExpress and eBay (including a countersink bit to carve out the underside of the car so the screw heads would be flush), below is the finished product. My boat came with mounts installed in the deck but I want to be able to slide the bimini. Does anyone have a good idea as to what to do with the original mount that's installed in the deck? Maybe snap a carabiner for a fender line there? Or just remove and fill the holes with epoxy.
I'm planning to get an 85"-90" bimini with the understanding that the tracks are 86" apart. I think one of these side walled biminis could be worthwhile. No need for a boom tent with one of these on board. The rails need to be cut down in order for the bimini to fit under the boom, so the side walls might just about cover the entire sides. Does anyone have any thoughts?
