Dinghy hoisting from solar arch with winch
xavpil
Sep 6, 2022
376
Jeanneau Sun Odyssey 419 Milwaukee
Hi all
i want to use my winch to lift the dinghy. (I don’t like the blocks and tackles systems)
what blocks do you recommend ?
attached is idea of what I am after
thx all
2,486
Is that your boat in the picture? Are you flexible about changes to the support frame?
PaulK
Dec 1, 2009
1,541
Sabre 402 Southport, CT
Is it an electric winch? Lifting a dinghy up that far will take a LOT of winching. Tacking with a Genoa usually only involves winching the last two or three feet. The height of your frame looks to be more like six to eight from the water, and you'd have to grind the entire time.
Jun 14, 2010
2,486
As @PaulK noted - a key idea is to use an electric winch.The frame in your picture is a bit complicated, with blocks to lower the stand-off/support bar and more blocks to hoist it on/off the bar. This video might give you some ideas to simplify it.
xavpil
Sep 6, 2022
376
Hahahaha. Not my world $$
but thx for contributing
xavpil
Sep 6, 2022
376
Not my boat but same idea minus the bar
the dinghy will be lifted 3-4”
planning on using the electric winch
xavpil
Sep 6, 2022
376
Electric winch, yes
Jun 14, 2010
2,486
Just use standard rigging blocks. Anything rated to carry the load. Just make sure you place a cam and secure cleat in the path to the winch and final angle of the line to the winch must be slightly below the winch (to avoid overrides).
Likes: xavpil
