Fire Port
May 1, 2011
5,595
Pearson 37 Lusby MD
I can't speak directly to a Catalina 310, but mine is installed on the front cover of the engine bay.
Nov 15, 2023
14
Catalina 310 242 New Orleans
On the 310, the front of the cover is also the companionway steps. Putting a port in the steps might make it hard to align a fire extinguisher vertically.
May 1, 2011
5,595
Pearson 37 Lusby MD
Do you have a photo you can share? On my boat, the steps have to be removed in order to remove the front cover of the engine bay, so I don't have the same limitation.
Nov 15, 2023
14
I don't have a photo. The cover is a large fiberglass box with steps molded into its forward side.
Jan 23, 2021
49
Catalina 315 81 Newport Beach
I don't have a photo available, but on the 315, the fire extinguisher port is located on the port side of the companionway steps, sort of in front of the galley refrigerator.
Nov 15, 2023
14
Here's a photo of the 310's engine cover / companionway.
Maybe the triangle area on the aft end would be a good place for the port. Low enough to get to the base of the flames. Extinguisher could be almost vertical. Or right under the latch.
