S2 7.3 Documented Vessel?
mtb369
May 29, 2023
10
S2 7.3 Minnetonka
Is it possible for an S2 7.3 to become a documented vessel, or is it just too small? I'm curious if anyone who owns a 7.3 has actually done it.
To meet USCG documentation requirements for net tonnage, the boat usually needs to be about 30' long.
On the CG webpage about documentation there is a form to complete to estimate net tonnage. The form is pretty simple, it needs LOA, beam, draft and a couple of other dimensions.
Likes: kloudie1
May 12, 2004
1,505
@dlochner, You are absolutely correct. I did not check the URL close enough but their info is correct. DO NOT go thru this company for documentation. They will do it , but at an exorbitant fee. Here is the official site.
Edit: OOPS! I see you already attached the URL. :facepalm:
mtb369
May 29, 2023
10
S2 7.3 Minnetonka
Convenient. That PDF I linked above will actually tell you if you're eligible once you populate the fields.
Looks like you're stuck with state registration numbers on your bow. ;) :beer:
