Let's have the exact number of the macerator. Close just ain't good enough when we're looking for the specs of the pump.I googled what looked like mine and reported that as the model number.
andWhat is the model number and age of your macerator pump?
Hi John. The diagram that the PO provided indicates the same setup as on our boat. One standpipe in the waste tank is used to empty the tank either through the deck pump out fitting or the macerator overboard discharge pump. The hose from the standpipe connects to a wye/tee fitting where one hose goes to the deck, the other to the macerator. He said the system pumps out just fine through the deck fitting, so, unless there is a blockage/air leak somewhere in the system, the macerator should work as well.You pump out using the macerator. The connection to the tank “4" plate installed “ is this a plate on the top of the tank? Is there a tube into the tank that the macerator sucks effluent up out of the tank? Is the tube clogged if it is being used?
The macerator sits up pretty high above the tank (about 18-24")
This could easily be the issue and might be worse than @Ralph Johnstone suggests as the pump draws from the bottom of the tank. It will get a slight boost when the tank is full because of the head in the dip tube, however, as the level drops, it loses that head and has to lift ever higher which it can't do. Add to that the back pressure from the pump being below the waterline and it will just sit there spinning its macerator.View attachment 221072
Looking at the limit for self priming, this is 0.6m = 23.6 inches. And usually this is wishful thinking for an impellor type pump on the part of the manufacturer. You mentioned that the macerator sits about 18-24" above the top of the tank but how far above the water line in the tank is the real question to ask. If the tank water level is 10" below the top of the tank, you may now be trying to pull something up to 30" which the pump just can't do. I think you may be a little too high for the pump to lift in order to prime the pump.
Unfortunately, both the "T" and the macerator will have to be lowered to just above the level of the top of the tank for this to work. Calculate if you have a small enough suction head when the tank is near empty for this to work,
In your drawing, what? The deck pumpout through the macerator? I gotta say no way can that be factory. Deck pump out completely off of the macerator line. Comes directly out of the tank. And dont trust those standard layouts in the manuals. My boat is completely different than what the book shows. My issue was similar, forward head, stock macerator would intermittently just bog down like it was clogged. I tried the screwdriver on the top of it to get it to turn. I took the lines off. My forward head has an elbow at the bottom, goes two feet to the pump, up and hook down then out the thru at bottom of hull. Drove me nuts cuz I couldnt solve it. More powerful macerator... decent results but. So this is witchcraft BUT, I prime the macerator with a few bumps (3 0r 4) of the pump out button for about a second each. My theory is that doing this brings the sludge up the race of the lines to the pump. However it works, it works. Your other option is to swap out and put a T series pump in.Thanks everyone!
My macerator is the Jabsco 18590-2094. When I stopped getting vaccuum I installed the 18598-1000 service kit since I thought the impeller looked a little worn. That did not help. I also have a new amarine 12GPM pump, which also is not able to get suction. Ralph, I did replace the O ring in the deck which didn't help. I ran a snake from the pump-out fitting and could see it go all the way into the tank. The line from macerator to the T is also clear.
I am not sure how a wye fitting will do anything different than the current T fitting. What would be the difference?
@dlochner, what voltage should I expect when the macerator is running? It will obvously drop some below 12.8v. I think this is a good suggestion though- it is a long run with pretty high guage wire so maybe some serious voltage drop along the way. I'll try running directly off a battery.
I am attaching another picture that shows how the macerator actually sits in the boat relative to the tank and thruhull. I am pretty sure the tank is below the waterline and I know the macerator is above (with the thruhull open, no water into the exit tube of macerator). Do you think if I reduce the distance "X" in the drawing that would help? That seems fairly easy.
As for a Y or wye value, what about a simple 1 1/2 pvc ball valve from Home Depot just on the deck pump-out side of the T?
Thank you for the good news. Hunter located our macerator pump below the waste tank. It would always change to a slightly higher pitched sound when the tank was pumped empty.I have a lot better understanding of the issue and a working (for now) system.
As mentioned by @Terry Cox , there is a very distinct rise in the pitch of the motor when the last drop ofAt least now that I have a 4" 'viewport' into the top of the tank I can see what is happening and not overrun the pump.
is discharged.Would this indicate that the pump is now just pumping holding tank farts and all the solid’s are gone?there is a very distinct rise in the pitch of the motor when the last drop ofis discharged.
Yup. Like most pump motors of this type, the RPM changes slightly when a load is removed. And I do mean several loads ofWould this indicate that the pump is now just pumping holding tank farts and all the solid’s are gone?
.Are you insinuating that there is a difference in density between holding tank farts and general run of the mill air ? How does the pump know this ? Please quote your source.the pump is now just pumping holding tank farts
