Trailer bunk bed carpet replacement
Sep 22, 2020
24
Hunter 23.5 Sag Harbor, NY
One of ends of my bunk board was damaged which I’ve had to replace. Will take the opportunity to replace the carpet of both at the same time. Just wondering which carpet people would recommend? This is for a Hunter 23.5 @Crazy Dave Condon suggestions???
Sometimes you can find "remnants" of outdoor grade carpet at Lowes or Home Depot and the manager will give it away. Just ask if they have any "small stuff" laying around in the carpet area. I'd still go with @BigEasy 's SS staples ...
Likes: Southern Crux
Sep 24, 2018
4,467
Catalina 30 MKIII Chicago
:plus: Use screws instead of staples. Much much easier and faster
Jun 2, 2004
3,646
I switched to the plastic covers I think they work much better, the boat slides right on. Another advantage is while the carpet retains moisture and keeps the bunks wet longer the plastic covers protect the wood bunks from the rain. The bunks last longer that way.
The one downside is the boat will slide right off too. Be sure it is right where you want it to come off the trailer when you unhook it.
Likes: Timm R Oday25
Sep 24, 2018
4,467
Some friction is good. A boat that's moving around on it's trailer is no fun to tow. Even going from 1" to 2" straps can make a noticeable difference
LloydB
Jan 15, 2006
927
Macgregor 22 Silverton
So I somewhat want to disagree with a couple prior posts because I've fastened a lot of stuff to walls, ceilings and floors with a staple gun and with screws. Staple gun is faster. Been reading Crazy Dave comments for several years now and he has made it very clear that one should not depend upon friction to keep your boat on the trailer when on the road, that has mostly been verified by YouTube and recreational viewing at the ramp. Sorry I don't have pictures right now:biggrin:
Likes: rgranger
Aug 2, 2009
651
Catalina 315 Muskegon
Or check Sailrite for the bunk carpet that they sell. I haven't used it for bunks, but have made fender covers with it. Highly resistant to UV and moisture.
