A
Anomymous 163294
upon further inspection as you suggested. here is what i found. and by what you have suggested , i am assuming that this happened when getting smoked in the front end? or is this caused by someone overtightening ? i also went to where the backstay attaches and its solid no cracks , not loose.After you address your damage on the nose, thoroughly inspect your mast, standing rigging, chain plates, anything that may be affected by a hard collision with a dock. The sudden stop at speed would put considerable stress on the tall aluminized pole standing 30' in the air. A lot of strain was taken by everthing aboard when that boat collided with whatever caused that damage. Keep in mind that masts flex in both direction, do there was strain on the forestay, as well as the backstays, when the masthead, sprung back against the stretch it put on the backstays.
-Will
