Where would I find the hull number of my Hunter 30? I have a 1989 Hunter 30 but wonder if it is a 30-2, a 30-T or a 30G.
My cabin hatch is cracked and I am trying to find a replacement. See photo. The outside aluminum frame dimension taken from inside is 10 5/8.
. I always forget about having acrylic cut by a plexiglass shop (same place you purchase the plexiglass) because I'm so accustomed to doing it myself. However, I don't remember seeing an original gasket under the glass when it was removed from the Bomar aluminum frame. The glass was dropped into position in the cleaned frame, held in position with taped pieces of wood on the underside and then injected with DC795 from the top. That was done back in 2010 and the 795 seams on the two 13" Lewmars and one 21" Bomar still look like brand new today.
