In the last month, I’ve developed random starting issues with motor and am trying to trouble shoot it.
Start up sequence is batteries and then ignition to on (only off/on ignition), push/hold glow plug 20-30 seconds, then push starter button while keeping glow plug button pushed in. Once the engine is warm I don’t need to push and hold the glow plug button, just the starter button to restart.
Perhaps 20%-30% of the time when I try to start engine by pushing the starter button, I get a buzzing alarm sound with pressing and the yellow alarm light on the panel coming on. The engine does not turn over when this happens. Turn off ignition, battery, then back on… wait a few seconds, to a minute or so and it starts right up but does seem to have an alarm sound (I don’t remember before) when pushing the starter button.
I’m thinking this is more of an electrical issue than mechanical with starting. Batteries were replaced last year with 205 AMPHR AGMs and hold at about 12.59 V after 36 hrs with instruments/radio running and motor will start. I hear fuel pump running/fuel circulating when the ignition is turned to on. I replaced the starter button last year (because the old one was sticking after pushing in). Glow plugs as best I can tell were replaced last in 2014 but the starting alarm seems to happen after the engine is already warm or recently run, not after it has been sitting for a few days and starting cold.
The starter and starter solenoid and panel plug are on the port side of the engine behind the alternator (attached photo) in a very easy to reach position if you are the size of a leprechaun. I’m thinking to get a non-contact voltage meter and try to start checking voltages without having to do do a lot of disassembly or replacements if possible.
Any thoughts on where I should be checking first or what may be causing the starter alarm buzzer and engine not starting?
