Discharge of sewage over 3 miles
Jan 20, 2020
34
Hunter H336 Milwaukee
here is my a section of my winterizing check list:
Here is a section of my Summarizing check list:
that's all I do!!
Likes: Dalliance
Oct 6, 2007
1,164
Hunter H30 1982 Chicago IL
that's all I do!!
I have a similar section on my check list. I also have to pull and drain the through hull tri-data transducer blank off after the boat is hauled. The speed paddle wheel is almost exactly where one of the slings goes, so it has to come out before lift and the blank off traps water between it’s O rings.
Jan 20, 2020
34
Good point, I do the same as far as removing the speed sensor, but I had never thought about removing the blanking plug - I will add that to mine - Thanks!!
Likes: Dalliance
Oct 6, 2007
1,164
I actually pull it out, dry it, and immediately put the blank off back in with a little silicone lube. One less item for the spring pre-splash check list.
