I have made mant post both inquiring and discussing my experience in replacing the acrylic fixed ports in my C30 Mk2 but did not create a thread of my own with the write-up of my experence here on SBO. This is the posting I did on the C30 Owners group and a couple of years overdue but better late than never.
I finished installing my fixed portlights in my 88 C30. In the originals, the lens was held in place with screws around the perimeter, but I used VHB tape and Dow 795. Here are some photos. The three vertical strips of white tape form a hinge to allow the lens to be properly aligned and then rotated up out of the way to strip the paper off the back and wipe down with alcohol before sticking to the tape.
I removed the old lenses with a kitchen paring knife that was thin and flexible enough to fit into the small gap and cut the old silicone.
I then used the original lenses as a template to cut new 1/4" "dark smoke" cast plexiglass to shape. After drawing the shape on the sheet of plexiglass, I cut the rough shape on my bandsaw and then stuck the old lens to the new rough blank with SailRite SeamStick tape.
Then I used a flush cutting router bit to trim the rough blanks to the same size as the originals. After switching to a 45º bevel bit with bottom bearing I cut the 45º bevel into the back side.
The original lenses were tight fitting with almost no gap around the edges and very thin layer of silicone between them and the cabin. If the sealant is too thin, it can cause leaks from thermal stresses, so I needed to make the new lens about 1/8" smaller. This also gave me a big enough gap to gun the silicone into. I did this by adjusting the depth of the 45º bevel deeper to cut the extra 1/8".
After cutting all of the old silicone off with a sharp chisel and cleaning it with sealant remover and sanding, we applied VHB tap to the edge of the opening and masking tape to the perimeter. Then we positioned the new lens in the opening and when happy with the location, added three tape "hinges" to the top to hold it in position.
The lens was flipped up, paper removed from back and cleaned with alcohol. Then the backing on the VBH was removed and the lens rotated back into place on its hinges. The alignment was perfect.
The project was then finished with black Dow 795.
So nice to have clear window for the first time in 20 years.
This is the setup just before positioning the new lens. One change I would do is not mask the cabin top until after the lens is set into the tape because it is hard to gauge where to place it. We were too wide which made it more difficult to smooth the surface after applying.
This shows the three tape hinges. This tape is 3M Preservation Tape and should be on every boat. I will stick incredibly well to fiberglass and stay waterproof all winter long. When you want to remove it, it comes off clean with no residue left on the surface. It was made to tape on the shrink-wrap winter covers.
The lenses stuck into tape without push sticks and no sign of edges lifting. These lenses were flat 30 seconds prior to photo and perfectly curved.
finished product speaks for itself!
