Lubricating sail slugs and mast tracks
Thanks... I guess kitche pans are not Anodized. Good to know.
jviss
Feb 5, 2004
7,090
Tartan 3800 20 Westport, MA
I think they usually are! Maybe yours are different enough to be immune. I've had some terrible staining from it on Aluminum pans, 'though they are still useable, just not pretty.
Likes: Leeward Rail
JBP-PA
Apr 29, 2022
711
Jeanneau Tonic 23 Erie, PA
I don't use anything so harsh. I take a handi-wipe aka wet wipe and attach that to my track cleaner (with staples!). After cleaning, it's dry and I soak it with SailKote. The handi-wipe is more durable than paper towels and it lasts long enough for one cleaning.
jviss
Feb 5, 2004
7,090
How tall is the mast?
That sounds like an easier way than carb cleaner on a rag.
Apr 11, 2020
801
MacGregor 26s Scott's Landing, Grapevine TX
Soaked the rag in carburetor cleaner spray and then ran the rag up and down the track. The rag came back NASTY!
Hey, don't get off track here (see what I did there?). You have just "invented" slug track cleaner (come to think of it, it might also eliminate unsightly slug tracks, right?). Just get a few 55 gallon drums of carb cleaner, some 8-oz metal cans and some label stock for your printer, market it as specially formulated slug track cleaner, and watch the bucks roll in! Please don't forget to invite me out to your palatial estate once you hit the big time. :cool:
  • Ha
Likes: rgranger
May 29, 2018
637
Canel 25 foot Shiogama, japan
If you have sand or gunk in the track spay will not remove it.
Here is some info that I posted back in 2019. Still relevant.
May 6, 2019
Do you have bolt rope or slugs?
If slugs, check then all for attachment and damage.
Do you have an internal mast track or an external mast rail?
If it is internal it could be restricted at the choke point by salt, sand or some other build up.
To both clean and check the condition of an internal track I highly recommend the
AMAZING DOCTOR GARY'S FREE TRACK CLEANER.
You need about a foot of rough cleaning rope that fits the track pretty snugly.
Parallel to the rope you whip on a piece of lighter line that is 2 or 3 inches longer at each end (See Pic 1).
There should be an eye in each end of the lighter line.
The whipping will make the diameter of the rough cleaning rope even snugger in the track.
Connect the main halyard to one eye and feed cleaning rope into track. (See Pic 2)
Connect a light down haul line to the bottom eye.(See Pic 3)
Haul up a yard or so and haul down a few times then repeat as you raise the line up the track.
Pay attention to the spot where you think the sail is binding.
When you have cleaned the whole track haul the cleaning rope
down , spray it with track lubricant and repeat the haul up/down to lube the complete track.
Will take 30 minutes to make the cleaner and 30 minutes to clean and lube the track. I do it once a year as a part of maintenance.
Good luck
Gary
jviss
Feb 5, 2004
7,090
May 6, 2019
Good luck
Gary
Great post and pics, thanks Gary. I would have to fabricate some different kind of cleaning swab, as the 'track' is rectangular in section, but the same idea will work.
jv
Oct 19, 2006
337
Hunter 27-3 Brownsville, VT/Mystic, CT
On the topic of marine lubricants, I just had a rigger down to my boat yesterday to retrieve my mainsail swivel, which was stuck at top of mast (there's a thread on that...).
Anyway, as we were chatting about various care & maintenance issues, he volunteered that he swears by Fluid Film as the best lubricant. He was quite enthusiastic about it.
Likes: rgranger
Sep 24, 2018
3,987
Catalina 30 MKIII Chicago
I've had great results from McLube and off the shelf dry teflon lubes but I do believe a clean track and slugs is more important. I find black gunk built up on the slugs at the end of the season. It takes about 40 minutes to clean them but the mast track took longer and was far less fun. This year I discovered that a melamine (magic eraser) sponge significantly speeds up the mast cleaning
Likes: jviss
Mar 26, 2011
3,838
Corsair F-24 MK I Deale, MD
Great info. Practical Sailor offers this idea for a DIY track cleaner: The Do-it-Yourself Sail Track Cleaner - Practical Sailor
Question - soak it in what?
I clean my track at least annually. Super easy once you get a track cleaner.
As for what to soak it in ... it depends.
  • First time, to remove mud dauber nests and crud, and hard surface cleaner soap is fine. Something aluminum-safe. Rinse with hose jet stream. If you keep the mast on an annual program, sail frequently, and don't sail in city, this is probably a one-time task.
  • After that, to remove built-up silicone and McLube, xylene is a good choice. Carb cleaner dries too fast and does not cut wax and silicone as well (because it dries too fast). Acetone dries to fast and does not cut wax well. Mineral spirits does not cut silicone and wax well enough. That has been my experience.
Likes: jviss
Apr 11, 2020
801
Awesome. Thanks!
Apr 5, 2009
3,211
What type of track cleaner do you have. My mast gate is just above the gooseneck so putting anything in that way requires removing all of the sail slugs.
Apr 5, 2009
3,211
My sail slugs are the 7/8" flat type and I have not found a good way to clean them with anything. The groove is too small for anything to fit inside.
Anyone with this type of slug have any good methods of cleaning and lubing the groove?
JBP-PA
Apr 29, 2022
711
I made my own track cleaner with a few inches of Bolt rope sewn into some spare canvas.
I too have to remove the slugs. I don't remove the sail though, I just slide out the slugs and the sail stays tied to the boom.
JBP-PA
Apr 29, 2022
711
I think some Total Boat Surface Prep would do a good job as solvent.
Mar 26, 2011
3,838
Jasper and Bailey Sailmakers make cleaners for that track. I've tested them.
Sep 24, 2018
3,987
I have the same style. See my quoted post below for cleaning techniques. I believe I used automotive pressure washer cleaning solution to clean the slugs since that's what was on hand
Apr 5, 2009
3,211
That sounds very easy if you pull your mast at the end of the season. My mast has been down twice in the 25-years I have owned Papillon and given that I am 65 and 250 I need a better reason that cleaning my sail track to go up the mast. ;)
